Column Lock Issue
Old Oct 21, 2009 | 11:11 AM
95jersey's Avatar
95jersey
Default Column Lock Issue
My buddies car is having a problem with the column lock, sometimes it wont start and he get a message that says "service column lock".
What is the problem and what is the best plan of action?
Old Oct 22, 2009 | 12:43 AM
dbirdhouse1's Avatar
dbirdhouse1
If it's an '05 there was a technical bulletin and fix....I bet if you checked around the site here you would find.....some "horror" stories involving forced towing due to that issue.....
Old Oct 22, 2009 | 01:30 AM
Shortimer's Avatar
Shortimer
Not aware of this problem with the C6. The C5, yes. Lots of post on this issue in the C5 section.
Old Oct 22, 2009 | 06:47 PM
Kent1999's Avatar
Kent1999
FYI - The 2005 C6 was the only C6 Corvette with the ill-conceived Column Lock mechanism -- 2006 and later C6's do not have the mechanism.
Old Oct 22, 2009 | 07:40 PM
HANNY's Avatar
HANNY
doesnt a relay control it? might be a simple fix to swap one from another componenent to that one
Old Nov 24, 2009 | 03:03 PM
Ahmer's Avatar
Ahmer
Is there a relay controlling this??? If so, where would this be??? Maybe I can fix it if the stinking dealer can't. My car is sitting at the dealership as I write this.
Old Nov 24, 2009 | 03:39 PM
vettedoogie's Avatar
vettedoogie
Could be a low battery. I'd make sure it has had the TSBs done AND check the present battery. I'd also recommend a battery maintainer. WalMart has a Schumacher SEM-1562A for $20 that works great.
Old Nov 24, 2009 | 04:09 PM
Hoonose's Avatar
Hoonose
More than 9 of 10 '05 column lock messages are do to a nearly dead battery coming to life and 'throwing codes'. If MN6 certainly you need to look for and treat DBS. Or may be a bad battery for all sorts of the usual reasons.
Occasionally the code is due to specific column lock issues, and there is a repair and TSB on the forum somewhere. And that would take a search...
Old Nov 24, 2009 | 05:44 PM
Hoonose's Avatar
Hoonose
http://forums.corvetteforum.com/c6-c...corvettes.html
To Column Lock Issue
