For some reason, I forgot to put the car in drive (automatic). Now I can't get into the car, codes are coming up all over in the DIC. The remote will not work. The remote will not let me in the trunk either. Any help would be appreciated??
Use the key to get in your hatch. The key pulls out of your fob. Key hole is above the rear plate. Door release cable is on the left wheel well inside the hatch in front of the fuel door release.
Then use the plastic lanyard pull on the drivers side fenderwell to open the driver door. Be prepared to have to re-charge the battery if the car was left in gear for any length of time.
Thanks, Jerry
Suspect you mean you neglected to put it in "Park." But do what the posters above have suggested.
A low battery in the C6 can make everything go crazy, electrically. Disconnect the negative terminal of the battery, then charge it overnight, then re-connect. Index the windows and you will be fine.
You need to get it charged, not jumped...unless jumping just to get it home to a charger.
