Dual tops
Old Oct 23, 2009 | 04:02 PM
MARSC6's Avatar
MARSC6
The painted top hasn't been on since the drive home from the dealer over 3 years ago. The only reason it was on then was because I could only stow 1 top in the back.
I drive with the top removed as much as possible so any heat from a clear top over summer doesn't matter.
Old Oct 23, 2009 | 04:06 PM
CQRT's Avatar
CQRT
Lexan roof from mid-October to late April - - -hard top during the summer heat.
Old Oct 23, 2009 | 04:08 PM
vettenut's Avatar
vettenut
KY Events Coordinator
Default Tops
I have painted & tinted clear. The painted one has never been used.
Old Oct 23, 2009 | 04:14 PM
SanDiegoBert's Avatar
SanDiegoBert
Originally Posted by 08VRCOUPE
I only have the clear and love it.
DITTO.
I've found that in San Diego, at least along the coast, the clear top is fine year 'round. I use a Canvasworks heat shield under the windshield when I park in the sun and the car stays reasonably cool. Or at least it does not get unreasonably hot.
One minor trick is to open the hatch first, and all the hot air climbs up, up and away. When the heat shield has been on, the steering wheel, dash, and sometimes even the seats are still cool.
But if you live in a hot climate, you need to cover up.
Old Oct 23, 2009 | 04:17 PM
Shortimer's Avatar
Shortimer
Mine came with the dual top option and the tinted panel was in place when I took delivery. After a year of driving with the that panel in place and hearing the occassional click, pop, crackles sounds, I removed it and installed the painted panel. I treated all the rubber surfaces with special lubricant and it was a perfect seal, no more noise. The painted panel is on for the Winter.
Old Oct 23, 2009 | 04:25 PM
FloridaGrandSport's Avatar
FloridaGrandSport
I guess it depends on the climate. My 3 previous coupes all had the dual option, and I found it more of a pain to find a place to store the one not in use than it was worth. Always preferred the painted, probably because it's hot in FL most all the time. I ordered my GS with just painted only, and figured if I really wanted the clear it would be easier to find than a CRM top. Now I just need the car to try it out.... 2 more months.
Old Oct 23, 2009 | 05:06 PM
Gordon Shumway's Avatar
Gordon Shumway
What he said, but I also use the painted one some in the winter as well. It just looks better on the car.
What I find in the summer is that there is a distinct temperature gradient right around my eyebrows. With the A/C on it is nice and cool from the eyebrows down, but pretty warm on the head from the eyebrows up.
Old Oct 23, 2009 | 05:26 PM
3GenVettes's Avatar
3GenVettes
The dual roof option is one of my favorite features with the coupes. Three C5 coupes with dual roofs, and three C6 coupes with the dual roofs. I like the open feeling with the transparent top, and use it 2/3 to 3/4 of the time. However, during the hottest summer weather I prefer the solid top. Also, I'll put the solid top on for a few days year round, just because I like the change up in appearance. Spring and fall days and summer nights the top often is riding in the back.
Old Oct 23, 2009 | 05:30 PM
2vette2's Avatar
2vette2
Veteran: National Guard
St. Jude 15 Year Donor
St. Jude Donor '09-'25
Originally Posted by ChefMark
Painted in the Summer and Clear in the winter
I guess I have is bass ackwards. I run the clear top in the summer and the painted top in the winter. The AC kepts me cool enough in the summer and the painted top seems warmer to me in the winter.
Old Oct 23, 2009 | 06:03 PM
2006c6keller's Avatar
2006c6keller
Default Schedule my dual tops.
Originally Posted by rwarhol
Witch top do you guys run the most, your clear top , or your painted top.
Only on short trips in the Texas or similar state type summer weather, I run the painted top. BUT on all long (weeks upon weeks) vacations and usually in the mountain states (14k mountains), I run the clear top with a plastic liner that can be easily removed and rolled up and stored in the trunk.
Old Oct 23, 2009 | 06:05 PM
2006c6keller
Default It will help!
Originally Posted by aeronos
Can I ask, does the transparent top get ridiculously hot in the summer? How 'transparent' is it?
You need a sunburn, it will sure help!
Old Oct 23, 2009 | 06:24 PM
BuckGW's Avatar
BuckGW
Same here - I run the painted top in July, August and September and the clear top the rest of the time. Once the temp gets into the 90's around here, the Clear top gets replaced.
Old Oct 23, 2009 | 06:26 PM
  #33
SanDiegoBert
It is 100% transparent, but it is heavily tinted a sky blue shade. This color very effectively blocks just about all UV radiation, which is the main cause of sunburns, I believe.
I recall a thread several months ago wherein a museum archivist tested the C6 clear top (polycarbonate) with a UV sensor. Not much UV detected, and he proclaimed it "archival quality" as I recall.
I doubt if you will get a sunburn while under it. I never have.
Old Oct 23, 2009 | 06:39 PM
  #34
haljensen's Avatar
haljensen
Same here, about 6 months each. I even have the static cling liner that helps a lot.
Old Oct 23, 2009 | 06:55 PM
  #35
lilpuu1's Avatar
lilpuu1
I did not know they have a suction cup type of headliner available. What brand or website could I look at one?
How do you like yours?
Old Oct 23, 2009 | 07:11 PM
  #36
General Lee's Avatar
General Lee
Originally Posted by Larry/car
Painted top in late spring, summer, transparant in early spring and fall, winter weather permitting.
thats what i do change with the seasons
Old Oct 24, 2009 | 01:03 AM
  #37
dbirdhouse1's Avatar
dbirdhouse1
I being in the Pac NW and really hot weather rarely a problem I sold the solid top and use the clear one exclusively.....wouldn't be a wise choice in many other parts of the country.
To Dual tops
Old Oct 24, 2009 | 01:26 AM
  #38
Major Hal's Avatar
Major Hal
I bouht my head liner fron DSV in May of 2007 and I have never taken it off except to clean! Works great! especialy in the summer here in SW Arizona
Old Oct 24, 2009 | 01:33 AM
  #39
gogetum's Avatar
gogetum
Witch top do you guys run the most, your clear top , or your painted top.[/QUOTE]
What about a broom?
Old Oct 24, 2009 | 12:37 PM
  #40
rwarhol's Avatar
rwarhol
Thanks guys i do the same thing, painted top in the summer, and clear top in the winter.
