sway bars
Old Oct 25, 2009 | 05:34 PM
azc62006's Avatar
azc62006
Default sway bars
im not sure if i can post this here but here it goes. im buying a NEW SET OF Z51 sway bars with bushing and end links.. i am going to sell my stock bars with end links and uerathane bushings. with a tube of poly lube. how much should i ask before i post them?
Old Oct 25, 2009 | 05:58 PM
C6NRED's Avatar
C6NRED
When you say "stock" do you mean that your original bars were Z51 already or base bars? If they are the base bars, they will be a tough sell as they are not an upgrade for anyone, and probably not worth the shipping costs alone....
DaveC6's Avatar
DaveC6
I'd say free. I don't think there is any market for base sway bars.
Old Oct 25, 2009 | 06:15 PM
azc62006's Avatar
azc62006
Default sway bars
thats what i thought.. so do you think it will be an upgrade from the base sway bars to the z51 bars? will feel a difference? does anyone know the size difference?
Old Oct 25, 2009 | 06:23 PM
FJONES96's Avatar
FJONES96
Default Sway Bar replacement
I just bought a 2008 Conv. After dealer inspection, they told me the sway bars were loose, leaking and needed replacement. Cost about $300.00. Any thoughts, if replaced should I upgrade to Z51 sway bars also? I am guessing the current ones are the basic. The car had 51K miles, but price was right.
Old Oct 25, 2009 | 06:36 PM
blueyeszr1's Avatar
blueyeszr1
Account suspended by request 6 Oct 2017
You will feel an amazing difference. I lost the specs for the standard bars vs the Z51 bars but the z51 bars are much bigger. I installed the Z51 bars with phaft bushings on my standard C6. It was one of the best and cheapest mods I have done. The car will handle much better,no body roll at all.
Old Oct 25, 2009 | 06:43 PM
Xedes's Avatar
Xedes
Why not just step up a bit and put the Z06 sways on. There doesn't seem to be a big additional cost?
Old Oct 25, 2009 | 06:47 PM
seevi's Avatar
seevi
I'd keep the stock rubber bushings!!!
Old Oct 25, 2009 | 07:06 PM
C6NRED's Avatar
C6NRED
Without the wider tires, you will have too much roll stiffness and your car will oversteer severly --- at least that is what I was told when I was going to go with the bigger bars....
Old Oct 25, 2009 | 07:13 PM
StanNH's Avatar
StanNH
You have leaking sway bars? Huh?
Old Oct 25, 2009 | 11:23 PM
FJONES96's Avatar
FJONES96
Sounds like I need to check into what they are talking about.
Old Oct 26, 2009 | 12:23 AM
DaveC6's Avatar
DaveC6
Was it a Caterpillar dealer? They don't contain fluid to leak and they don't ever need replacement.
Old Oct 26, 2009 | 01:11 AM
ssv3's Avatar
ssv3
Old Oct 26, 2009 | 05:27 AM
rectifyer2000's Avatar
rectifyer2000
Did they try to sell you any chrome plated muffler bearings with that raw deal? I hate dealership service! Check out Pfadt sways if you want even better performance.
Old Oct 26, 2009 | 06:18 AM
SlideRulz's Avatar
SlideRulz
I put the Z51 sway bars about a year ago, what a differance it made.
I couldn't even give the stock ones away.
Old Oct 26, 2009 | 09:33 AM
Charley Hoyt's Avatar
Charley Hoyt
Originally Posted by C6NRED
Without the wider tires, you will have too much roll stiffness and your car will understeer severly --- at least that is what I was told when I was going to go with the bigger bars....
I believe you mean oversteer.
Old Oct 26, 2009 | 11:12 AM
C6NRED's Avatar
C6NRED
Yup......corrected my post.........thanks!
To sway bars
