1st gear problems
Old Oct 28, 2009 | 03:03 AM
Dans 98 corvette's Avatar
Dans 98 corvette
Default 1st gear problems
Sometimes it takes almost 4 trys to get into first gear. Everytime I stop at a red light It won't let me put it into first and I have to try several times. Its sooo annoying. Took it to the dealer and they couldn't find anything wrong with it. Im thinking maybe the fluid has to be changed?
Old Oct 28, 2009 | 03:41 AM
chiefzusaf's Avatar
chiefzusaf
I used to have that problem when I first started driving stick shifts but then I finally figured out that if I pressed the clutch pedal it went into gear easier...:-)
Old Oct 28, 2009 | 03:47 AM
cmnguye8's Avatar
cmnguye8
I have that problem also, just shift to second for a brief second then back up to first.
Old Oct 28, 2009 | 07:30 AM
Vettes Rule's Avatar
Vettes Rule
I recycle the clutch with a couple of pumps and while light is still red I try to put it into 1st for a second to make sure it will go. I try not to roll after this because sometimes problem may come back. This does not happen all the time, but I find myself preparing for it at every stop.
Old Oct 28, 2009 | 08:17 AM
Walt White Coupe's Avatar
Walt White Coupe
This is pretty much normal for the T-56 trans in 05 to 07 cars. The manual says that if it won't go into first, move to neutral, let out the clutch and try again. That always worked but at a red light you'll get someone blowing their horn at you. Going to second first never worked for my trans. If you're on a hill, just let the car roll a little and it will slip in. Sometimes I'd just start in second. Or start a roll in second and drop it back into first.
The beauty of new transmission is that this never happens.
Old Oct 28, 2009 | 12:18 PM
cranky's Avatar
cranky
need to change the fluid regularly. clutch is dragging. not opening up all the way due to the fluid being thin and contaminated. if you go to second first, you are just wearing the second gear syncho rings out early.
Old Oct 28, 2009 | 12:36 PM
FireRoc's Avatar
FireRoc
I have an 05 C6 and it does the same thing. My understanding is that it has to do with the shape of the gear teeth on the synchro rings (flat on top).
When mine will not go into first, I either let it roll a little bit (less than than a foot is all that is needed) or will put it in second, let the clutch just a little bit to get the car to roll (less than a foot) and then go back to first. If I do not have time to do this (impatient people behind me) I just start in second gear.
Old Oct 28, 2009 | 08:55 PM
Bumble_Bee's Avatar
Bumble_Bee
This happens to me as well, kind takes the fun out of driving the car.
If my vette didn't do this, the car would be perfect. Does switching to non-GM fluids correct this problem?
Old Oct 28, 2009 | 09:07 PM
bps999's Avatar
bps999
if you dont mind holding the clutch in during the red light, you can put it in first as your slowing down, but before you stop. i.e. match revs and downshift to first as you approach the light. Mine seems to like this better than if I try to shift to first while at a complete stop.
Old Oct 28, 2009 | 09:34 PM
David Lasic's Avatar
David Lasic
This is really not an unusual thing to occur. It happens sometimes in my '05 C6 and sometimes with the Muncie wide ratio 4 speed box in my '69 C3. I just shift into second and back up into first. That takes care of it.
Old Oct 29, 2009 | 05:57 PM
Dans 98 corvette
Oh ok thanks for the feedback, I guess i'll try changing the fluid. I have 46k and haven't changed the fluid yet so guess I'll give it a shot
Old Oct 29, 2009 | 06:15 PM
Walt White Coupe
It won't help. It's a mechanical design problem with the way first gear is cut and a different lube isn't going to change that hard fact.
Old Oct 29, 2009 | 06:26 PM
don7790's Avatar
don7790
I put in Royal Purple and have reduced the instances of the problem to the point of it rarely happening. It also helped on cold shift problem.
Old Oct 29, 2009 | 06:39 PM
deviledGTO's Avatar
deviledGTO
My 04 GTO is notorious at doing this. does it with reverse too. My 07 vette not so much. I go back to neutral, then let the clutch out, and it goes in like butter afterwards. its just really annoying to have to do that. and yes ppl get pissy sometimes.
Old Oct 29, 2009 | 06:56 PM
Dans 98 corvette
hmm maybe ill try the royal purple fluid. Everyone seems to like that stuff
To 1st gear problems
