Throttle sensor error
Old Oct 28, 2009 | 02:42 PM
dcox7980's Avatar
dcox7980
Default Throttle sensor error
Has any ony ever had this code pop up? My trac light is on and service engine light is on. Is there any way to clear this code my self?
Old Oct 28, 2009 | 02:54 PM
BearZ06's Avatar
BearZ06
St. Jude Donor '09 thru '17,'22 thru '26
Several parts stores have code readers and will read and clear the code for you. Call and check with the most popular Zone and Advanced brands.
Old Oct 28, 2009 | 10:42 PM
bub's Avatar
bub
Not on my Vettes, but I did get this on my '07 Tahoe 5.3L just recently.
TPS replacement is not as simple as it was in the past. It is no longer a $30 part you screw on to the throttle body. Now GM only "services the part" as an entire $200+ throttle body. The TPS clips to the throttle body, and it can be interchanged, but it is not sold separately. Go figure.
That is the way it was on the Tahoe...assume it is similar on the LS engines with drive by wire...
Bottom line, the replacement throttle body (complete w/ new TPS potentiometer) fixed the SES ("Service Engine Soon") light problem I was having on the Tahoe.
You can always reset it (the SES) as a "quick fix", I did myself a couple of times, but you will likely find the SES comes on more frequently as the TPS ages and goes from bad to worse, throwing the SES light and code P0121 I seem to recall?) more and more often, until it goes from an every couple months type deal to a daily deal when the TPS is near shot.
Good luck.
-CKB
Old Oct 29, 2009 | 01:06 AM
dgrant3830's Avatar
dgrant3830
Wounded Warrior Escort '11
Could this be your drive by wire gas pedal position sensor rather than the throttle position sensor out in the engine?
To Throttle sensor error
