Help! Center caps keep falling off!!
Old Nov 7, 2009 | 02:03 AM
acrebs21's Avatar
acrebs21
Default Help! Center caps keep falling off!!
I ordered some chrome center caps off ebay and put them on a few weeks ago.. AS SOON as I left my driveway and pulled on the 4 lane, I lost 2 and never found them.. So I ordered 2 more.. When they came in, I drove 5 mins up the road, and realized 1 had came off again from the same side the others fell off.. So I ordered one more.. I put it on about a week ago and it was fine until today.. I noticed the SAME center cap came off again! What can I do to keep it from coming off? Thanks
Aaron
Old Nov 7, 2009 | 03:26 AM
07c6vette's Avatar
07c6vette
Aaron
did they come w/ metal clips at the back?
Old Nov 7, 2009 | 03:33 AM
acrebs21's Avatar
acrebs21
Just the things that snap onto the wheel, i dunno if that is what you are talking about or not. The guy who sells them told me to put some sort of silicone on them or something. I don't want to put anything on to make it hard to take off when I am getting new tires or something, but I don't want them to keep falling off...
Old Nov 7, 2009 | 07:36 AM
sjohnson2615's Avatar
sjohnson2615
I just installed a new set of centercaps on my P car and bought cap locks for them.They are for anti theft and to keep them from coming off.
I am sure they are wheel/cap specific,but you might try the manufacturer for your wheels and see if they make them for the wheels you have.They work great.
I got mine from Pelican Parts.You can look at those and see if they might work on yours.They are only around $5 each.
Old Nov 7, 2009 | 07:59 AM
weathermaker's Avatar
weathermaker
Sounds like there may be a problem with the wheel. Check where the cap tabs clip in, are there any burrs or imperfections in the holes or slots? Good luck!
Old Nov 7, 2009 | 02:38 PM
Roger@CCC's Avatar
Roger@CCC
Default Center cap retaining ring
Here is a photo of the C6 aftermarket chrome center caps that we use for our customized graphics center caps. Note the spring wire ring that applies extra pressure to the "tabs" that snap onto your wheels.
They seem to hold on better than the ones without the ring. We had one customer who lost one, but he hit a pothole hard.
Roger@CCC
Custom Center Caps
Supporting Vendor
Old Nov 7, 2009 | 02:43 PM
Vette5.5's Avatar
Vette5.5
Get a hold of a heat gun(not a hair dryer) to soften the plastic mounting tab's, and pull them out a little. That should do it.
Old Nov 7, 2009 | 08:58 PM
07c6vette's Avatar
07c6vette
Roger@CCC
Custom Center Caps
Supporting Vendor
that's the metal spring i was refering to
Old Nov 8, 2009 | 01:21 PM
CYOUL8ER's Avatar
CYOUL8ER
Can you clear silicone them in from the backside?
Old Nov 9, 2009 | 11:53 PM
2006c6keller's Avatar
2006c6keller
Default Solved hub cap problem, the problem is flexing!
I have lost them with AND without the spring clip and this is how I solved the problem. I ground down the ends of the "petals" with my bench grinder. I have not lost one in over two years and I have been on some of the roughest roads in the country for a Corvette, I have put at least 25K or more miles on them. I used no lube at all, only grinding to prevent the flexing of the wheel which works them off. Note: If there is not enough room for flexing, they will pop off, I have lost three or more before I started grinding them, NONE since.
Old Nov 10, 2009 | 11:01 PM
cmonkey713's Avatar
cmonkey713
Yep! this the trick. I have done this for several years on numerous Corvette wheels. I lost the first center cap, a member here on the Forum suggusted silicone. No more lost caps.
Old Nov 10, 2009 | 11:08 PM
acrebs21's Avatar
acrebs21
Well I received the cap I ordered today for the one that fell off, and I put silicone on it.. It won't be coming off now :-).... hopefully..
To Help! Center caps keep falling off!!
