Exhaust Install
Old Dec 12, 2010 | 11:14 AM
mack morrow jr's Avatar
mack morrow jr
Originally Posted by Dave O
If you have an auto, you have to bend the heat shield. Watch the video in the attached link (very good) or see the instructions in the second link. Hope this helps
http://www.ecklers.com/product.asp?d...6912&video=yes
http://www.borla.com/media/installations/11745.pdf
If I am only using the axle back with no change in h pipe do I have to make any other adjustments?
Old Dec 12, 2010 | 01:04 PM
haljensen's Avatar
haljensen
Originally Posted by Mike's Sweet 05
Congratulations on completing your conversion. One quick question is did you have any problems repositioning the sway bar after you loosened it and were you able to retighten the end links on the bar without any damage? 2005 mn6.
Thanks.
Mike
Don't touch the end links. Just unbolt the 2 bolt and 2 nuts on the sway bar brackets and let the bar swing down, the end links aren't touched by a wrench.
