NPP muffler conversion
Old Nov 15, 2009 | 07:57 AM
Chalie M's Avatar
Chalie M
Default NPP muffler conversion
Looking to install the NPP mufflers on my 07 coupe auto, (I bought the car with flowmasters on it which I like at idle and when pulling away from a stop but when cruising with my wife the dreaded drone gets a little anoying) does anyone have the p/n's of the mufflers necessary for the install, and what year mufflers work, is it true they changed them for the 09's.
Chalie
Old Nov 15, 2009 | 08:43 AM
sxeC7's Avatar
sxeC7
St. Jude Donor '06-'07-'09-'10
C6 '08 Factory NPP's are the only ones that fit w/o modifications. With Z06 NPP's, you'll need to use your overaxle pipes and weld them to the muffler's. Later C6 NPP's have a different hanger system. The C6 NPP's sound better than the Z06's IMHO.
Old Nov 15, 2009 | 11:01 PM
K9KUZ's Avatar
K9KUZ
I went with the NPPs on my 05 (with the M2W controller). Found the mufflers right here in the Parts section (but it did take looking constantly for a few days). New ones are too much $$ IMHO. As far as I know, only the 08's will fit correctly.
Old Nov 15, 2009 | 11:26 PM
AtHomeSoda's Avatar
AtHomeSoda
Default Ah...
The ZO6 Bi-Mode mufflers are NOT NPP, you can cut and weld the pipes, and it STILL will not sound like the NPP...the ZO6 are quiet when open...they have a perferated baffle inside... NIGHT & DAY.
And yes, only the 2008 will bolt right on... You can find Take-off's for less than the NEW price of $1500-1800... E-Bay... normal with NPP in a box goes for $1099... FYI
To NPP muffler conversion
