The manual says to remove the lower rear panel that the lights are attached to. Looks like 2 screws/bolts in the center and 3 or 4 push/pull retainers on each side.
I replaced my backup lights with LEDs and I did it just by reaching up from underneath the car as I indicated in my first post. No need to remove anything.
Well that's good to know. Saves me a little bit of a hassle. Thanks!!
I just replaced mine. The wires are not long enough to just reach up there and replace the bulb. There are 4 small screws underneath the diffuser that will allow you better access to that area.
From: Out Where the Buses Don't Run, Eglin AFB/ Niceville FL
2022 Corvette of the Year Finalist -- Modified
2021 C6 of the Year Winner - Modified
2020 C6 of the Year Finalist - Modified
I just swapped to LED on my 06. I was able to reach in and grab the socket and pull it down to swap the bulbs. It's tight but it can be done. My neighbour did the same on his 09.
