Installed a complete new audio system
Old Nov 18, 2009 | 11:38 PM
Odin's Avatar
Odin
Default Installed a complete new audio system
Kenwood DNX9140 navigation head unit with USB input, iPod interface, Sirius radio, Kenwood backup camera.
Used the stock Corvette nav antenna in the dash and it works great
I kept the OnStar active with a GMOS-01 interface that I rigged to work with the Corvette and used the factory center channel speaker for the OnStar and door chimes.
Also did a PAC SWI-JACK steering wheel interface for wheel controls.
Ran the USB input cable and iPod cable into the center console so they're hidden. I had to file out 2 small notches in the plastic under the console lid so the cables could pass into the console compartment.
Mounted the subwoofer level control **** in the ashtray where the cig lighter used to be.
JL Audio CL-RLC line driver/subwoofer level controller, JL Audio HD600/4 amplifier, Focal 165KRX2 component speakers, JL Audio Stealthbox subwoofer.
Custom startup screen loaded onto the DNX9140.
Hard to get a decent pic of the head unit in the garage with a flash.
The dash kit is textured and painted to match the stock dash plastic.
The sub level control **** is mounted behind the closed ashtray door.
Subwoofer level control where the cig lighter used to be.
This controls the JL Audio CL-RLC line driver/sub level control of the amp.
Focal tweeter mounted on a custom panel in the stock location.
Invisible normally, but the camera flash shows behind the grill a little.
Focal midrange mounted on a custom 1/2" MDF panel in the stock location.
It's normally not this visible but the camera flash really brought out the Focal cone through the grill.
JL Audio Stealthbox in the left read storage compartment.
The line you see across the sub grill is where the roof panel rubber molding sits when the roof panel is mounted in the back.
The JL Audio HD600/4 amplifier is hidden in the other rear storage compartment, not much to see there. 4-gauge power cable fused at the battery going to the amp.
The sound quality is night and day different from the stock system, as it should be.
I really liked the HUD integration of the factory navigation unit, but since I don't daily drive this car and rarely use navigation in either car it's not a big deal.
The iPod interface of the Kenwood unit is light years better than any interface for the factory unit.
The entire installation (including fabricating the speaker mounting panels, sub level control mount, etc.) took me the better part of 2 days, but I'm very satisfied with it.
Old Nov 19, 2009 | 12:08 AM
Rule292's Avatar
Rule292
St. Jude Donor '11-'12-'13-'14-'15-'16
Finally found something that sounds good on the factory center channel speaker, eh!
Good job!
If someone were to make an HUD interface, I would say that the aftermarket audio market would rocket for the C6.
Old Nov 19, 2009 | 12:09 AM
Latch's Avatar
Latch
Awesome setup! Congrats on getting it all done.
Old Nov 19, 2009 | 12:14 AM
okbkvette's Avatar
okbkvette
WOW, obviously, not your first rodeo.... I couldn't understand half of what you wrote, but looks great
Old Nov 19, 2009 | 12:19 AM
NYC6's Avatar
NYC6
Its another whole dimension in sound reproduction isn't it?
Old Nov 19, 2009 | 12:54 AM
Knob Jockey's Avatar
Knob Jockey
Nice Work!
Looks like you got a good match on the NAV trim and OEM.
Do you have any pics of the Backup Cam install and how you passed the cable through the rear panel?
Old Nov 19, 2009 | 02:37 AM
VETTE-NV's Avatar
VETTE-NV
16 Vettes and counting…..
Excellent job! Great location for the sub control.
Once you get a good sound system into the Vette, it becomes very apparent just how bad the Bose system really is. I upgraded my stock NAV system (kept the head unit for now) with an Alpine PDX-5 amp, two Subthump rear boxes with 10" RF woofers, some Eclipse speakers for the rear, and an Alpine component system for the doors. Also added the Peripheral IPOD interface and replaced the XM module with the Sirius one.
By completely eliminating the Bose system, you can actually get great sound from the factory head unit, although I know replacing it would improve it even more. You chose the exact head unit I was thinking about.......seeing yours installed just closed the deal for me.
Old Nov 19, 2009 | 04:22 AM
Grzldvt1's Avatar
Grzldvt1
Very nice, bet it sounds great!!!
My neighbor was pretty happy with his Blose system until he got into my car with my custom setup. We are pulling his Blose and setting his up identical to mine.
Old Nov 19, 2009 | 05:33 AM
LS2-Zomb!e's Avatar
LS2-Zomb!e
Very nice!
Old Nov 19, 2009 | 06:52 AM
james2292's Avatar
james2292
Old Nov 19, 2009 | 07:53 AM
Chuck Bensinger's Avatar
Chuck Bensinger
How did you install the Corvette scrip on the screen? I have a Kenwood 6140 Nav. and that would look GREAT!
Old Nov 19, 2009 | 08:16 AM
AORoads's Avatar
AORoads
St. Jude Donor '15
"In honor of jpee"
You obviously know quite a bit about what you're doing. Frequently, I've read here that electronic issues follow not long after such an installation, specifically, battery dying. Of course that can happen if a ground isn't correct but what about too much draw or the stock charging system including the battery just can't keep up? Did you do anything else or is the system the same load?
Old Nov 19, 2009 | 09:13 AM
BSE1956's Avatar
BSE1956
High quality parts and a real nice installation.
What did you do with the rear 5.25" speakers?
Old Nov 19, 2009 | 10:04 AM
Odin's Avatar
Odin
Originally Posted by **** Jockey
Nice Work!
Actually the rear cam in in the garage not installed yet because it was backordered and came in after everything else. I'll post a pic once I get it installed, I haven't looked yet to see how I'm going to do the install.
Old Nov 19, 2009 | 10:07 AM
Odin's Avatar
Odin
I don't know if this works on the 6140, but it should. Some of these instructions might not be the same for the 6140 if the icons and controls are different, but you'll get the idea.
On the DNX9140...
First you will want to save your settings by going to SOURCE SELECT and touching the arrow at the top right side of the screen, select the Wrench icon and touch SYSTEM, page down to the last option, SETUP MEMORY. Save your settings to recall later.
Next you will need a USB flash or thumb drive. Create a folder called "PICTURES" on the USB drive and place your image of choice in the folder. Remove the drive from your computer and follow these steps:
Turn unit on and hold down buttons: SOURCE and VOLUME DOWN, Hit the RESET button once. The unit will reboot, continue holding the SOURCE and VOLUME buttons until the screen illuminates. You can now release the buttons.
You will see the setup screen, touch OEM, at this point you can plug in your flash drive, select USB and select the name of the drive that appears.
Navigate to the PICTURES folder and select your image. Hit OK, the unit will pause for a few seconds and return to the previous screen. Hit the RESET button once more and allow the unit to boot.
You should now see your custom startup screen. Restore your saved settings.
Old Nov 19, 2009 | 10:11 AM
Odin's Avatar
Odin
The only thing I added that draws additional current is the amplifier. I used a Class D amp which is highly efficient and draws minimal current unless you're really pounding on the system. If you play the stereo for several hours while the car is not running I suppose it would draw the battery down, but with the car running there is no issue with current draw.
I suspect that a lot of current draw issues with Corvettes could be when people add an aftermarket amplifier with the factory radio. The factory radio doesn't have a remote turn on output, so people often use a switched ignition wire to turn on the amp, which means the amp is on any time the key is on.
Old Nov 19, 2009 | 10:13 AM
Odin's Avatar
Odin
I only installed front component speakers and the subwoofer, no rear speakers.
I am considering some rear speakers, which would require an additional amplifier for the sub (moving the rear channels of my current amp to the rear speakers). I would do this for more volume, not improved sound quality (rear speakers actually hurt the sound quality by moving your sound stage behind you).
To Installed a complete new audio system
Old Nov 19, 2009 | 10:23 AM
peter pan's Avatar
peter pan
Life Time NCM #2196
Nice looking install and really looks factory
Old Nov 19, 2009 | 12:03 PM
CYOUL8ER's Avatar
CYOUL8ER
Very niiiice! - I would pass on the rear speakers though - Your soundstage right now should be perfect - any way you can send me you start up pic? I have the same HU
Old Nov 19, 2009 | 12:20 PM
Odin's Avatar
Odin
I can't take credit for the background, I found it on this forum.
Check this thread for some good stuff.
http://forums.corvetteforum.com/audi...ds-thread.html
