Sure, I'll crawl under my dash tomorrow when I get home from work and take some pics of the led's.
The fog lights took about an hour. It would have been quicker but since I am planning to do a "how to" post, I did it the hardest way possible for those that may not have a garage or a jack. I did it by just turning the wheels instead of removing them. Either way, a very easy install.
I would appreciate the pictures and the DIY. I have an LED light kit from a previous car that I will be installing inside. Plus need to place my order with JW for the HID Fog upgrade. Just need to decide on 4300k, 6k, or 8k?
Is there any danger or concern to going to the brighter lights (i.e. heat, power, etc.)? My lighting knowledge is not the highest.
Deiger
The pictures I took tonight didn't turn out so good. I'll try doing it in the morning under a natural light and see which ones are better and post them. Sorry about the delay.
I had 6k on a previous car and now 8k on this one. I would say the 6k are close to the color that Audi headlights put out. I will most likely be ordering the 6k for my headlights, but then again, the 8k look so darn good at night.
Xedes, How did you remove the reading light cover to replace it with the new leds. It looks awesome.
All it takes is a very small / thin standard screwdriver. If you look at the lenses, there is a small notch on each of them to place the screwdriver in. They just pop right out.
The bulbs are pretty hard to get out though. I used the same small screwdriver and took my time to pry it out slowly but I did read somewhere to take some painters tape (I imagine any tape would do the trick too) and wrap part of it around the bulb leaving enough leftover tape to use as a type of pulley.
Just ordered mine. Do all of the interior light covers come off the same way? (hopefully without breaking)
Yes they do. The ones under the dash are pretty tough to get out so use a larger screwdriver and don't be afraid to apply a little force. The lights are sort of in this shape -|_|-, so work on one side, not the middle.
If you want I can take mine out and take an actual picture of them to help you better understand?
