oil filter question
Old Nov 24, 2009 | 02:24 PM
ronandsue74's Avatar
ronandsue74
Default oil filter question
I need to change my oil soon.
I have a 2006 3LT Automatic. I've only owned it since August, so this will be my first oil change.
Can I use either the Delco UPF46 or the Mobil 1 M1-107?
Are these the right and best oil filters for my car or is there something better out there?
Thanks in advance!
RJ
Old Nov 24, 2009 | 02:31 PM
fnbrowning's Avatar
fnbrowning
From studies where the oil filter is cut apart and examined, the best filters are (in no order) Bosch, Mobil 1, Wix and K&N. Application charts are at any parts counter.
Whatever you do, don't run a Fram.
Old Nov 24, 2009 | 07:08 PM
LMB-C6's Avatar
LMB-C6
I'm sure there are better filters than AC - but that's what the factory installs, and they need to stand by it if fails, so based on that, I use an AC oil filter. Any place that sells them will be able to look up your application or have the application guides there for you.
Old Nov 24, 2009 | 07:16 PM
Mad*Max's Avatar
Mad*Max
I've used AC Delco and NAPA Gold in mine.
Old Nov 24, 2009 | 07:37 PM
Vette Suspension's Avatar
Vette Suspension
I just figure Mobil 1 oil Mobil 1 filter.
Old Nov 24, 2009 | 07:46 PM
jabez's Avatar
jabez
I like K & N's
Old Nov 24, 2009 | 07:51 PM
lander's Avatar
lander
St. Jude Donor '09-'10-'11
I use the Mobil 1's. Been using them on my vehicles for years now...more habit than solid reason though.
Old Nov 24, 2009 | 08:01 PM
JERGENSEN LS3's Avatar
JERGENSEN LS3
From: New Jersey - National Corvette Museum Member '08, '09, '10, '11, '12
I always use Mobil 1 filters. Never had a problem...worth the $$$
Old Nov 24, 2009 | 09:06 PM
JoesC5's Avatar
JoesC5
Only problem I've ever had with a defective filter was a Delco that the dealer installed on my C5 during an oil change. I switched to WIX, Mobil1 and K&N because a motor is a terrible thing to waste.
Old Nov 24, 2009 | 09:24 PM
RogerC6's Avatar
RogerC6
From: Some where in Amerika, sadly watching how is turned into a Socialist Republic.
By the way is a PF48. JMO
Old Nov 24, 2009 | 09:39 PM
JoesC5's Avatar
JoesC5
2006 LS2 takes a PF46 filter. The PF48 is only used on the LS7(Z06).
Marc V.'s Avatar
Marc V.
Old Nov 24, 2009 | 09:42 PM
tommy grantham sr.'s Avatar
tommy grantham sr.
I used the AC GOLD.Tommy
Old Nov 24, 2009 | 09:52 PM
RogerC6's Avatar
RogerC6
46 is LS1...48 is used on both LS2, LS3and LS7. The 46 fits but is different inside (pressure valve).
Old Nov 24, 2009 | 10:08 PM
Mike Green9's Avatar
Mike Green9
After reading much info on the subject of oil filters, NAPA Gold seems to be one of the top dogs. I use them exclusively on my C6 and STS.
M.....
Old Nov 24, 2009 | 10:13 PM
JoesC5's Avatar
JoesC5
No I'm not.
Read slow----- 2005 & 2006 LS2 takes a PF46, 2006 LS7 takes a PF48. The OP has a 2006, you have a 2007. A 2007 LS2 takes a PF48. A 2008, 2009 & 2010 LS3 Takes a PF48. ALL LS7's take a PF48.
The PF44, and it's direct replacement PF46, do not have a bypass valve in the filter as it is part of the engine assembly. GM changed that for the 2007 year(the 2006 LS7 has the PF48) and moved the bypass valve to the filter, thus the change to a PF48 designation because the bypass valve is part of the filter. To make sure the two filters(PF44/46 and the PF48) were not interchangeable they changed the tread diameter and pitch of the mounting hole. PF44/46 has a 13/16-16 hole and the PF48 has a 22X1.5mm hole. A bypass valve is not a pressure valve as you state. The bypass valve is set to open at 16psi to allow oil to bypass the filtering media incase of any blockage.
Old Nov 24, 2009 | 10:37 PM
RogerC6's Avatar
RogerC6
No I'm not.
Hey use what ever turns you on, you want to turn this into a **** contest find another contestant, use a filter from a Prius for all I care.
I know what the correct filter is. Thank You.
To oil filter question
Old Nov 24, 2009 | 10:38 PM
NYC6's Avatar
NYC6
No I'm not.
You're 100% right!
Old Nov 24, 2009 | 10:48 PM
JoesC5's Avatar
JoesC5
It wasn't my intent to turn it into a pissing contest. I only wanted to correct the misinformation you posted before someone did damage to their oil pan trying to force a PF48 filter on the threated stud where a PF46 is spec'd. The OP was correct, as was I, in what filter is spec'd for a 2006 LS2, a PF46. You came back with the smart *** reply, that you later edited out.
You don't know jack s**T.
Old Nov 24, 2009 | 11:24 PM
cclive's Avatar
cclive
The LS2 engine changed oil filter requirement in 2007 to the 48. Before that, the LS2 used a 46.
Page 6-14 of the 2006 Owners Manual says PF-46
Page 445 of the 2007 Owners Manual says PF-48
