trans fill location
Old Nov 25, 2009 | 01:27 PM
slm119's Avatar
slm119
5th Gear
Default trans fill location
where is the fill location for a c6 ( non z06) for the trans fluid?
Old Nov 25, 2009 | 01:28 PM
mksz51's Avatar
mksz51
Auto or manual?
Old Nov 25, 2009 | 01:29 PM
slm119's Avatar
slm119
5th Gear
auto
Old Nov 25, 2009 | 01:30 PM
mksz51's Avatar
mksz51
Sorry - can't help you - I only know the manual. Did you check the owner's manual?
Old Nov 25, 2009 | 01:33 PM
slm119's Avatar
slm119
5th Gear
no, there is a post on the forum for a trans fluid change on the z06.. Mine is different. There is a rubber boot on the front of the trans. Just wondering how to tell when full.
Old Nov 25, 2009 | 01:41 PM
mike72's Avatar
mike72
To check the fluid level in an auto( A6) is a very tedious and drawn out proceedure. It is spelled out in the repair manuals but I don't have a copy here to show you. Sorry. The fill plug is on the passenger side of the trans and is a rubber insert. It is fairly hard to see and to get out. You might do a search and see if someone has posted the procedure.
Old Nov 25, 2009 | 01:42 PM
RicK T's Avatar
RicK T
This might be more than you wanted to know but it's good info:
http://forums.corvetteforum.com/c6-c...-question.html
And a little filling trick from Chuck CoW:
http://forums.corvetteforum.com/1566984738-post41.html
Old Nov 25, 2009 | 01:56 PM
slm119's Avatar
slm119
5th Gear
thanks for the reply. I can't find a drain or fill plug on either side. I drained the fluid from the trans pan, changed the filter and gasket, but can find no fill location.
Old Nov 25, 2009 | 03:28 PM
thesubfloor's Avatar
thesubfloor
From: Brentwood World's first A6 in the 9's (including N/A, blower, turbo and nitrous cars) 9.950@139.267 CA
PM me with your phone number and I can talk you through it.
To trans fill location
