smell
Old Nov 27, 2009 | 10:21 PM
king off the hill's Avatar
king off the hill
Default smell
bad smell
Old Nov 27, 2009 | 10:23 PM
mikez51c6's Avatar
mikez51c6
St. Jude Donor '11
Old Nov 27, 2009 | 10:26 PM
RadarP3C's Avatar
RadarP3C
Bad drugs?
Old Nov 27, 2009 | 10:28 PM
Dans C6's Avatar
Dans C6
wtf?... is this thread all about.
Old Nov 27, 2009 | 10:29 PM
king off the hill
Originally Posted by RadarP3C
Bad drugs?
2005 start motor smell musty goes away after 5 min
Old Nov 27, 2009 | 10:34 PM
basacowan's Avatar
basacowan
St. Jude Donor '11-'12, '14
Air conditioner drain blocked, possibly needs cleaning and perhaps replace cabin filter.
Old Nov 27, 2009 | 10:39 PM
king off the hill
thankyou i have 16000 mi anything else i can do
Old Nov 27, 2009 | 11:27 PM
cclive's Avatar
cclive
Good info also use punctuation be good thing ok yes
Old Nov 27, 2009 | 11:29 PM
rmedina's Avatar
rmedina
Try running your A/C in the open mode for a few days..
Old Nov 28, 2009 | 12:04 AM
ShockwaveGT's Avatar
ShockwaveGT
clean the cabin filter...or wipe your ***.
Old Nov 28, 2009 | 12:06 AM
Raazor's Avatar
Raazor
Goon Squad King of Battle
St. Jude 15 Year Donor
St. Jude Donor '08 thru '23
both
Old Nov 28, 2009 | 12:11 AM
Low12s's Avatar
Low12s
From: Life isn't about waiting for the Storm to pass, it's about learning to dance in the Rain.
Soap and water
Old Nov 28, 2009 | 09:14 AM
leatherneck21's Avatar
leatherneck21
You need to trade your car in for a ford focus...then it wouldn't smell
Old Nov 28, 2009 | 09:47 AM
basacowan's Avatar
basacowan
It doesn't really matter how many miles the car has. If something is blocking the trap and I mean anything even during manufacturing that gets caught can cause mold and backup. If you get mold the problem will have to be treated accordingly. As aq previous post stated run the air conditioning on full and get a spray treatment from one of the national chains and follow the instructions. What happens to the smell when you run full heat - any worse? Only other thing I can think of is a critter made it's home somewhere in your ventilation system.
Old Nov 28, 2009 | 09:50 AM
bubba871's Avatar
bubba871
Take a shower. Use soap.
Old Nov 28, 2009 | 10:05 AM
king off the hill
Originally Posted by radarp3c
bad drugs?
hey radar shake your head
Old Nov 28, 2009 | 10:09 AM
king off the hill
Originally Posted by leatherneck21
you need to trade your car in for a ford focus...then it wouldn't smell
not in my lifetime
To smell
Old Nov 28, 2009 | 10:10 AM
king off the hill
It might smell but i love it
Old Nov 28, 2009 | 10:22 AM
ByByBMW's Avatar
ByByBMW
St. Jude Donor '06-'08-'10-'11-'12-'13 '14-'15-'16-'17-'18-'19
Other than the rude comments, the folks are trying to tell you to run your system and maybe use some Lysol or other disinfectant spray in the system and also change the cabin filter. This is usually caused by not allowing the A/C to dry out after use. Turn off the Air Conditioner a few minutes before getting to your stop. This allows the ice/moisture to dry up and minimizes the mold and mildew from building up.
Hope that helps.
Old Nov 28, 2009 | 10:30 AM
king off the hill
Originally Posted by bybybmw
other than the rude comments, the folks are trying to tell you to run your system and maybe use some lysol or other disinfectant spray in the system and also change the cabin filter. This is usually caused by not allowing the a/c to dry out after use. Turn off the air conditioner a few minutes before getting to your stop. This allows the ice/moisture to dry up and minimizes the mold and mildew from building up.
Hope that helps.
thankyou i will try that today im in alaska its cold i dont use air much
