Key FOB Question?
Old Nov 27, 2009 | 10:25 PM
jprog7's Avatar
jprog7
Default Key FOB Question?
Hi,
I unfortunately lost my key fob (#2)tonight. Anyways, I looked on GMPartsHouse.com and noticed that there are 3 different types of Fobs for an 08 Coupe...one without a remote entry lock, one with a remote entry lock (specific frequency), and one with a remote entry lock (low frequency). What one should I be using?
Thanks,
Jeff
Old Nov 27, 2009 | 11:23 PM
cclive's Avatar
cclive
Send a PM to Gene (at GmPartsHouse)...there are only two fobs for '08, #1 and #2. The only difference is the number printed on it. If you lost the whole thing, then you will need to also order the key that goes inside it and have that cut to match once you receive it. You can program it yourself using the instructions in the FAQ section here on the forum.
