Squeaking Under Acceleration?
Old Nov 28, 2009 | 07:16 PM
jpuli28's Avatar
jpuli28
Default Squeaking Under Acceleration?
When I apply the gas Im hearing a squeaking noise, my first thought was the belt. But at 3yrs old and 19.5k mi it looks fine and is tight.
Could it be the tensioner pulley?
Posted in Tech also
Old Nov 28, 2009 | 07:23 PM
2006c6keller's Avatar
2006c6keller
Posted in Tech also
Why don't you check and see if the tensioner is WITHIN its adjustment limits! It is a visual check with the mark between the lines, if not, readjust.
Old Nov 28, 2009 | 07:33 PM
jpuli28's Avatar
jpuli28
There arent (or I didnt notice) any "lines". Its notched so it cant really exceed its limits without "popping out" of the groove.
Old Nov 28, 2009 | 07:41 PM
robertpel9's Avatar
robertpel9
I just had to replace my belt too and it looked perfect.
$20 at napa and 5 mins later squeaking is gone
Old Nov 28, 2009 | 07:46 PM
jpuli28's Avatar
jpuli28
How old/mi was it?
Old Nov 28, 2009 | 10:00 PM
2006c6keller
Default Take another look!
Your not looking in the right place, look by your oil filler cap on the passanger side of the engine and you will see the belt and the tensioner WITH raised lines on it. I have a 06 C6 LS2 and I believe that is the same engine you have. I just looked at mine to best describe where to look. Good luck!
Old Nov 28, 2009 | 10:04 PM
jpuli28's Avatar
jpuli28
I went out after your first post and saw what you meant, thanks.
So where is the "in between" lines. Is it the first large gap (from bottom '0' to 1st line) or the second smaller gap (line 1 to 2)?
My tensioner is right about at the 1st line.
Old Nov 29, 2009 | 09:29 AM
07 Z51's Avatar
07 Z51
It is most likely the belt or the tensioner.
If you ever get squealing under acceleration, check your passenger as that is the most likely source.......
Old Nov 29, 2009 | 01:40 PM
jpuli28's Avatar
jpuli28
Old Nov 29, 2009 | 11:42 PM
jmt1669's Avatar
jmt1669
St. Jude Donor '11
Sounds like groundhog day for me. Mine stated with a squeak then a day or so later a strange metal tapping at about 2500 rpm. A trip to the dealer revealed a loose balancer. Check yours. My car is an 06 wth the same miles as yours.
Old Nov 30, 2009 | 12:01 AM
jpuli28's Avatar
jpuli28
Yup, its gotta wobble to it... Off to the dealer I go
I found this thread too...
http://forums.corvetteforum.com/c6-t...2-2006-c6.html
Old Nov 30, 2009 | 12:10 AM
SweetBlueZ51's Avatar
SweetBlueZ51
I had my harmonic balancer replaced under warranty. It was making some severe chirping sounds. Pay close attention to see how much it's wobbling. It had to get a little worse than this for the dealer to finally replace it, but now that it has been replaced, it's perfect. Maybe you have the same problem.
http://www.youtube.com/watch?v=vRboo9a0RnY
Old Nov 30, 2009 | 12:16 AM
jpuli28's Avatar
jpuli28
I saw that video too, thanks. Fortunately Im close with my technician so I dont think he'll make me come back. I read if its not addressed it only gets worse, why would your dealer make you come back, its inevitable you will!
Old Dec 1, 2009 | 06:53 AM
jpuli28's Avatar
jpuli28
Its the harmonic balancer, service appt on Fri. No vette for me this weekend.
Old Jan 29, 2010 | 10:03 AM
CandyVette's Avatar
CandyVette
Mine is being replaced as I type this.
At first they thought it was just my belt so they replaced that but the squeaking continued, and the squeaking was especially bad in cold and/or rainy weather. Husband took the car back and they didn't hear squeaking so they said it was okay (on a warm day). Not okay. When I took it back in yesterday morning it was squeaking like a banshee, and I drove in the service bay and revved the engine so that the squeaking could be heard by everyone in a ten-mile radius. I got out of the car, looked at my service guy and said, "Did you hear THAT?"
Is this another widespread problem with C6's? All I can say is, thank goodness I have an extended warranty!
Old Jul 24, 2018 | 08:52 PM
Ricosuave24's Avatar
Ricosuave24
Default Noise on acceleration
I had the same thing and turned out to be the serp belt, it accumulates coolant, and other oils from engine and starts slipping.
Old Jul 24, 2018 | 09:42 PM
ruxvette's Avatar
ruxvette
2016 C6 of Year Finalist
Rico, however suave you are you are 8 years late to the party. Carry on, tho...
To Squeaking Under Acceleration?
