Clock
Nov 29, 2009 | 11:58 AM
6th Gear
Clock
How do you get clock out of military time?
Nov 29, 2009 | 12:00 PM
From: Stafford VA, home of our wolf den. No house break ins to date.
Honorable Discharge.....................
hee hee j/k
cant remember off the top of my head but its clearly in the owners manual
Nov 29, 2009 | 12:04 PM
Quote:
Originally Posted by
Wilma
Depends... Do you have the Navigation system or not?
Nov 29, 2009 | 12:07 PM
St. Jude Donor '07-'08-'09-'10-'11-'12-'13-'14-'15-'16
Wilma
Non-Navigation System:
Navigation System:
Nov 29, 2009 | 01:33 PM
6th Gear
No Navigation - its a 2005 Vette. Thank You
Nov 29, 2009 | 01:43 PM
Wilma
That information is not in the 2005 owner's manual, but it is in some of the later ones.
Nov 29, 2009 | 07:18 PM
Setting the Time
With the ignition on and the radio off, press the H or the
M button to enter clock mode. Press and hold H until
the correct hour appears on the display. Press and
hold M until the correct minute appears on the display.
To change the time default setting from 12 hour to
24 hour, press either the H or the M button to enter
the clock mode. Press the tune **** to select between
the 12 or 24 hour display format. The clock mode
automatically times out with the changed display
format set as the current default setting.
Nov 30, 2009 | 12:58 PM
6th Gear
Thank You - that fixed it.
Nov 30, 2009 | 12:59 PM
6th Gear
Thank You - I appreciate your help. I fixed it.
Nov 30, 2009 | 05:39 PM
wolfdogs
hee hee j/k
Wolfdogs, I needed a laugh today, thanks! That was a good one!
Nov 30, 2009 | 06:11 PM
subtract 12 if its showing 13 or more. I'm too slow.
