Help removing nav unit
Old Nov 29, 2009 | 03:29 PM
saplumr's Avatar
saplumr
Default Help removing nav unit
Can anyone tell me the procedure for removing the factory nav unit and how hard it is.
Old Nov 29, 2009 | 03:32 PM
DjCritterus's Avatar
DjCritterus
St. Jude Donor '09
This might help along with the search button
http://www.skyhighphotos.smugmug.com...70787982_9eMaw
Old Nov 29, 2009 | 04:18 PM
saplumr's Avatar
saplumr
That's not much help. I just want to know how to remove the head unit for replacing. There's no help in the search.
Old Nov 29, 2009 | 04:23 PM
Paratrooper307's Avatar
Paratrooper307
Just pull the center console out, which will require the removal of the fasteners under the console lid, and underneath the parking brake boot.(You can see most of these in the pictures in the link) You will also have to remove the shift ****, and disconnect any electrical connections (seat heaters, suspension, hazard switch) Then the console can be pulled out. From there it is just four bolts holding the unit in, and you can slide it out and disconnect the wiring harness.
Old Nov 29, 2009 | 04:25 PM
saplumr's Avatar
saplumr
I guess thats what I needed. I thought it may be a simple removal without removing the console like a lot of units pull out with a tool.
Old Nov 29, 2009 | 04:36 PM
DjCritterus
St. Jude Donor '09
Yep. Start from the back of the arm rest and work your way forward. Be careful unplugging all the connections because most of them are difficult to get to and and unhook. It's all in the pics.
Old Nov 29, 2009 | 05:04 PM
Rabeah22's Avatar
Rabeah22
It was very easy to do I did it myself on the driveway. Take out the clip where the tour and sport button is and take off those two screws. MAKE SURE YOU KEEP YOUR CENTER CONSOLE OPEN. Then unclip the rest of it. You will find screws as you go. Just remember how everything went in when you first took it apart and you will be fine. Remember there are two screws near the passenger console for the trim piece.
Old Nov 29, 2009 | 05:06 PM
saplumr's Avatar
saplumr
I've had the center console out before and replaced with the new CF piece. I just hate the thought of taking it back out again.
Old Nov 29, 2009 | 05:19 PM
lander's Avatar
lander
St. Jude Donor '09-'10-'11
Really? Weird.
http://forums.corvetteforum.com/c6-c...up-w-pics.html
Old Nov 29, 2009 | 05:25 PM
saplumr's Avatar
saplumr
Originally Posted by lander
I guess I should have said I didn't prefer to wade through 30 minutes of search as you did.
Old Nov 29, 2009 | 06:11 PM
lander's Avatar
lander
I guess I should have said I didn't prefer to wade through 30 seconds of search as you did.
Fixt.
You have to use some common sense. Since it's audio related, head to the audio section. From there you'd have seen the C6 FAQ, in which was the link to the above thread.
Old Nov 29, 2009 | 06:18 PM
saplumr's Avatar
saplumr
Fixt.
Thanks for the education.
Old Nov 29, 2009 | 06:24 PM
DjCritterus
St. Jude Donor '09
It comes out the same way and then you'll see two bolts (maybe four.. can't remember) that hold the unit in place. It's one of the easiest to remove out of all the cars I've owned in my short span gracing the world with my presence.
At least you're not in PR&C. It's brutal in there. On another note, i find searching the forum quite fun as I usually come across a thread or tid-bit of info unrelated to my search that comes in handy. I have a post ***** tendency but spend most of my time searching past threads. Lots of good info here
Old Nov 29, 2009 | 06:34 PM
lander's Avatar
lander
My other vehicle is a '98 Exploder Sport...cut a coat hanger into two pieces, bent them into a "U" shape, stuck them in the holes on the radio and pushed outward...radio pops right out.
Now the new Kenwood that's in it's place...that beast requires taking the center dash out now.
To Help removing nav unit
