Operating Temp
Old Nov 29, 2009 | 05:42 PM
BAblackvette's Avatar
BAblackvette
Default Operating Temp
Okay guys just checking, Im sure im just being paranoid about this stuff, but here goes.
I changed the coolant yesterday, put in 6.3 quarts of dexcool concentrate and filled as much water as i could after driving around a bit, and letting it work the air out of the system. I didnt used distilled water, just filtered water figured it probably wasnt too big of a deal since the manual just says to use "clear, drinkable water".
I never really noticed the coolant temp before, checked it out now though, i never remember it fluctuating that much! it goes from 204-208 around while crusing and up to around 218 when idling for a while. Is this normal and okay?
Old Nov 29, 2009 | 05:51 PM
C8-Vette's Avatar
C8-Vette
Seems a bit high. With out side temp in the 50/60 I run 196- 198 at cruise. You my still have air in the system. Keep checking the reserve tank.
Old Nov 29, 2009 | 05:52 PM
N8sFavToy's Avatar
N8sFavToy
Sounds normal to me. Normal for cruising seems to be just over 200 for me. Not sure about idling for a while, but 10 degree jump seems normal. Very hard driving can get up there too.
Not sure where you live, but if its still warm there, it makes difference of few degrees. IDK for sure but Z51 may differ from base model too.
Old Nov 29, 2009 | 06:19 PM
VET4LES's Avatar
VET4LES
Sounds normal. My driving temp is 196 depending on weather and heavy traffic will make it go up to 215 +/-.
Old Nov 29, 2009 | 06:45 PM
BSE1956's Avatar
BSE1956
mine's about the same.
Old Nov 29, 2009 | 07:00 PM
LucaBrasiAZ's Avatar
LucaBrasiAZ
same here
Old Nov 29, 2009 | 07:07 PM
knkali's Avatar
knkali
200-205 up to 220's in stop and go esp in the summer
found this to back it up:
http://forums.corvetteforum.com/c6-t...e-concern.html
Old Nov 29, 2009 | 07:11 PM
Rogers 07's Avatar
Rogers 07
Temp fluctuations are normal. The electric fans dont kick in until about 215. Its not unusual to see 15-20 degree temp swings while the fans cycle. Just keep an eye on your expansion tank level and you should be fine.
Old Nov 29, 2009 | 07:43 PM
BAblackvette
Awesome guys, I really appreciate the feedback. I gotta check the cold full levels on my surge tank once I locate the lines, I eyeballed it before but couldn't find em, ill check it again though thanks again guys
Old Nov 29, 2009 | 09:10 PM
woulddug's Avatar
woulddug
Turn Heater and Defrost on, to make sure you circulate all water and air
Old Nov 29, 2009 | 09:49 PM
knkali's Avatar
knkali
good idea
Old Nov 29, 2009 | 11:26 PM
bps999's Avatar
bps999
my 07 Z51 runs around 200 when it's getting good air flow to the radiator, and will go straight to 220 within a minute or so at a stoplight. so, I say your temps are normal
Old Nov 30, 2009 | 01:59 AM
Mike's LS3's Avatar
Mike's LS3
Freeway driving 192 - 196
city driving 200 - 220, fans kick in around 220.
2008 LS3, 6 sp. manual, Z51,NPP.
Old Nov 30, 2009 | 02:15 AM
Rossi6998's Avatar
Rossi6998
Same here....
To Operating Temp
