06 console update
Old Nov 30, 2009 | 11:06 AM
rwklatt's Avatar
rwklatt
3rd Gear
Default 06 console update
I have a 06 ragtop and I wanted to update the console to the new 08 carbon fibre look when they came out, but GM told me the clips were different and it would not fit. Has there been a retro fit introduced yet? I tought I could do it while the car is stored over winter.
Old Nov 30, 2009 | 11:43 AM
bbster's Avatar
bbster
Default 08 Console
I had an 06 vert and put in an 08 console with no issues. I think that you were told incorrect information.
Old Nov 30, 2009 | 12:48 PM
sprinkler's Avatar
sprinkler
I agree, I think you were given the wrong information. I installed the 08 console in a 2007. The 2007 had the same silver console as you have. Great mod!
Old Nov 30, 2009 | 12:53 PM
j_digi454's Avatar
j_digi454
Same here.
Old Nov 30, 2009 | 03:37 PM
gpmarsha's Avatar
gpmarsha
Old Nov 30, 2009 | 04:38 PM
C-INRED's Avatar
C-INRED
St. Jude Donor '06
I also put the '08 console in my '06 (coupe). There were no problems other than having to modify the F55 switch. If you don't have F55 it should be a direct swap with no modificaitons. If you have F55 Ray Kawal has instructions for making the switch conversion pigtail.
Old Nov 30, 2009 | 05:14 PM
mcandrew67's Avatar
mcandrew67
2016 Corvette of Year
2015 C6 of Year Finalist
Just another endorsement that it does fit, I put one in my 06 Coupe also.....
David
Old Dec 1, 2009 | 12:15 AM
GotVett?'s Avatar
GotVett?
Mine's still sittin on the floor with my MGW shifter. Waiting for my DSVettes leather goods to also come in to get the full impact, all at once.
Old Dec 1, 2009 | 12:19 AM
wolfpack06's Avatar
wolfpack06
I've been wanting to do this... how much does it cost? Where are you guys buying from?? I like the leather/carbon fiber ones.
Old Dec 1, 2009 | 07:55 AM
peter pan's Avatar
peter pan
Life Time NCM #2196
Buddy did this to his 06 Z and it does look good, time to do it
Old Dec 1, 2009 | 08:41 AM
Bandit1's Avatar
Bandit1
Originally Posted by j_digi454
Same here.
Yep, me too. Installed the 08 4LT console in my 06. Clips and bolts holes are identical. Removal and install is exactly the same. Ordered mine from Gene Culley.
Old Dec 1, 2009 | 08:47 AM
SilverScorp's Avatar
SilverScorp
Ditto as well. I installed an 08 console in my 05 which is the hardest to do because of the orientation of the power receptacle in the console. However, it was still easy to do and fit without any issues. The clips matched right up.
Old Dec 1, 2009 | 09:51 AM
rwklatt's Avatar
rwklatt
3rd Gear
Thanks everyone, I do have the F55, but that should be no problem. Now I just have to find one.
Old Dec 1, 2009 | 10:14 AM
j_digi454's Avatar
j_digi454
Forgot to mention, I also have the F55. I bought the adapter cable from Ray Kawal. The cable and his instructions for removing and putting the console together were great. Search for Kawal, he is a Forum member.
Old Dec 1, 2009 | 11:14 AM
AFRET's Avatar
AFRET
Default 08 Console
Does anyone have a picture of the console? and how much does it cost? I have an 06 coupe; becoming very interested in doing this.
Old Dec 1, 2009 | 11:47 AM
mcandrew67's Avatar
mcandrew67
I did some other stuff too....
Old Dec 1, 2009 | 11:56 AM
LOUSVETTE's Avatar
LOUSVETTE
NCM Member
If you happen to have a red interior, Gene at GMPARRTSHOUSE.COM has the one withe the red CF and it looks great (I had it in my 2008 coupe) He has a picture on his site under "C Parts List"
To 06 console update
Old Dec 1, 2009 | 12:06 PM
Bandit1's Avatar
Bandit1
Here you go. Pics of both the 3LT and 4LT consoles.
http://forums.corvetteforum.com/c6-c...hlight=bandit1
Old Dec 1, 2009 | 11:48 PM
C-INRED's Avatar
C-INRED
St. Jude Donor '06
Here is Ray Kawal's write-up on the '06 F55 console swap. This was my car that we made the swap on.
http://www.kawal.net/F55%20console.htm
Ray used to make and provide the conversion pigtails for a nominal cost. I don't know if he does this any longer but it would be worth checking with him.
If you're looking for a new console Gene is a great source. He will help you make sure you get the correct one.
Good luck with the swap. You'll be very pleased with the result.
Old Dec 2, 2009 | 01:01 AM
mpuzach's Avatar
mpuzach
The mod you're considering is a great one. You'll love it, trust me. You might consider going the DS Vettes route. Gerardo starts with a factory bezel (either the 2008-09 style or the 2010 style), removes the "pleather" from around the edge, and replaces it with stitched leather. You choose the color(s) you want for the leather and the stitching. It's especially cool if you have a 2-tone interior; the leather around the edge of the console bezel can be done in the same 2 colors as the 2-tone interior.
One other thought - if you upgrade the console bezel, you might as well do DSV's leather shifter and e-brake boots! Here's a pic to give you an idea:
