C6 Jacking!!
Old Dec 1, 2009 | 11:45 AM
Coralkid54's Avatar
Coralkid54
Default C6 Jacking!!
As a very new C6 owner, I would like to double check if it is OK to jack one corner of the car at a time using pucks (and my low profile race jack) at the hoist point to remove a wheel (I need to clean the back side of the wheels) or if you have to jack as per the handbook? ie. jack under the suspension housing as shown for the front and rear.
I am not sure if the four corner points on the under-tray are for a "four point lift " only on a hydraulic hoist.
Perhaps someone can clarify for me? Thanks!:
Old Dec 1, 2009 | 11:47 AM
Pylons's Avatar
Pylons
jacking at one puck point at a time is a-ok
Old Dec 1, 2009 | 12:36 PM
cclive's Avatar
cclive
When I had a tire repaired, they jacked up the one corner and insisted on opening the doors and the hood because older Corvettes had alot of flex in the chassis. So I let them do it, but then checked once it was up and nothing had flexed at all. The doors closed and all the lines between panels were absolutely straight etc. The C6 has a very stiff frame and jacking up one corner is fine.
Old Dec 1, 2009 | 01:00 PM
jimmie jam's Avatar
jimmie jam
i did my pads one wheel at a time with no issues at all (vert). help yourself
Old Dec 1, 2009 | 01:04 PM
mksz51's Avatar
mksz51
Absolutely fine to do what you are suggesting. Fair warning - some on this forum have made jacking one of these cars up into a science with special adapters for jacks, etc. That's fine - it's also overkill. Just be careful with your jack pad/puck interface so the car doesn't "slide" off the jack and to make certain you aren't contacting the rocker panel ('cuz they do crack).
Old Dec 1, 2009 | 01:10 PM
ufso's Avatar
ufso
Try the STICKYS above!
Old Dec 1, 2009 | 01:17 PM
MCSSLT1's Avatar
MCSSLT1
hell i can even jack mine without pucks without damaging the car
Old Dec 1, 2009 | 01:20 PM
GOLD72's Avatar
GOLD72
Old Dec 1, 2009 | 01:23 PM
Carnac's Avatar
Carnac
When I jack the front corner (with a jack pad) the rear tire will come off the ground also. This was with a 05 C6 Z51. My 08 Z06 does not quite lift the rear when the front is jacked. No problem with doors, hood, or hatch. Cheers - Jim
Pylons's Avatar
Pylons
and actually, with a decent jack, you can get both wheels off the ground at once by just jacking at one puck point
Old Dec 1, 2009 | 06:01 PM
Nutshell's Avatar
Nutshell
and here I was thinking there was gonna be some C6 **** in this thread..
Old Dec 1, 2009 | 06:21 PM
ls2kev's Avatar
ls2kev
Cars are females anyway. Shoulda known better.
Old Dec 1, 2009 | 07:10 PM
inthehunt2's Avatar
inthehunt2
The chassis is absolutely bullet-proof. No worries at all to jack it at one of the puck points. Perfectly fine for the C6 and C5. I can't say anything about the C4 and prior however.
Old Dec 1, 2009 | 07:14 PM
Tin Star's Avatar
Tin Star
From: Amelia Island,FL ______ or DFW _________ Sold my 05 MS Coupe ____ bought 08 Vert Blk/JSB, 3LT, F55
C6 Jacking!!!!
I thought this was going to be about a stolen car
Old Dec 1, 2009 | 07:21 PM
lh4x4's Avatar
lh4x4
Already he is cleaning the inside of the rims!
To C6 Jacking!!
