TSB Numbers
Old Dec 4, 2009 | 04:54 PM
azcanuk's Avatar
azcanuk
Default TSB Numbers
I know they are in here somewhere but when I do searches not finding what I'm looking for.
I need the TSB numbers for:
1) Differential Chatter (dif oil changel)
2) End Link issues
3) Hub Lock (Axle nut?) issues
4) Creaky Roof at latches
I'm have to take the car in for "noises" coming from the rear of the car and I'm going to insist they do all of the necessary work to cover these three TSB's..
DREADING having them touch the car..
Thanks moocho!
Old Dec 4, 2009 | 05:55 PM
bob guzzy's Avatar
bob guzzy
Everything you need to know about recalls tsb's and more can be found here
http://www-odi.nhtsa.dot.gov/recalls/
Old Dec 4, 2009 | 06:57 PM
08vycpe's Avatar
08vycpe
Keep in mind dealers are under no obligation to perform any TSB's. TSB's are provided to the dealers to help them diagnose customer concerns based on previous learning. If the dealer decides your fix is not related to the TSB, they won't necessarily apply it. If you car doesn't exibit the concern and you just want it done they won't do it.
BTW...the TSB for the roof rattle is a sticky from Talon90 at the top of the page.
To TSB Numbers
