C6 "Issues" ?
Old Dec 7, 2009 | 06:15 PM
skylarkul's Avatar
skylarkul
Default C6 "Issues" ?
I'm looking to step up the an 07 or 08 C6. I'm just wondering if the C6s have issues like the C5s? E.g., "Service Active Handling" and "Column Lock" that drive us up the wall. It won't stop me from buying one but, I would like to know what may be lurking out there.
Les
Old Dec 7, 2009 | 06:27 PM
mcandrew67's Avatar
mcandrew67
2016 Corvette of Year
2015 C6 of Year Finalist
I have 51k miles on my 06 and have had neither of those problems
All I have had is
*Flying roof replaced.
*AC compressor replaced
*A6 shifter stuck, replaced
*Ashtray door popping open, replaced 3 times
Other than that nothing. Been running like a dream.
David
Old Dec 7, 2009 | 06:34 PM
VET4LES's Avatar
VET4LES
Les
Only the 2005 has the colum lock and it's not a problem.
Old Dec 7, 2009 | 06:41 PM
Rule292's Avatar
Rule292
St. Jude Donor '11-'12-'13-'14-'15-'16
Les
Oh, there have been a few accidents/crashes of C6's caused by a supposed active handling "bug". No recalls or fixes yet, but the NHTSA does have a spate of complaints.
Only mechanical issue I have with mine (other than winter itself) is that the battery dies after just a few weeks of not using the car. Commonly known issue.
Another is the cold shifting/grinding issues that plague the manual trannies. Once it warms up, all is well.
I gotta 'vert so I don't have roof popping issues. There was one convertible part recall, it was a two minute dealer fix and NBD.
Other than that, no real issues in a year and a half of ownership.
I say go for it. C6 seems to be well built for a GM.
Old Dec 7, 2009 | 07:15 PM
RACN1320's Avatar
RACN1320
'08 here just shy of 30k miles. I've had the following:
* Popping top fixed with some silicone grease
* Alignment out from the factory
* Assorted rattles neither I nor the dealership can locate
* Popping differential on low speed turns when cold. Fixed with a lube change under warranty
Old Dec 7, 2009 | 07:31 PM
wolfdogs's Avatar
wolfdogs
From: Stafford VA, home of our wolf den. No house break ins to date.
im at 5300 and have had not one issue what so ever. knock on wood...
well..except for the "popping roof"..which a fix with Vaseline at the joint cured it.
Old Dec 7, 2009 | 07:38 PM
Zymurgy's Avatar
Zymurgy
Moderator
Take a look at the Service Bulletins at the NHTSA for the years you are considering. This will give you a pretty good idea of the common issues. Not everyone will experience these issues, but they are common enough that GM issued a bulletin.
Old Dec 7, 2009 | 07:40 PM
dvilin's Avatar
dvilin
Good advice.
Old Dec 7, 2009 | 09:02 PM
PCMusicGuy's Avatar
PCMusicGuy
Have 34k miles on my 07 (daily driver).
Plenty of rattles, the hatch pull down motor doesn't always work (even since brand new) and occasionally when I start the car the radio (speakers) makes a popping sound. Other than that it has been great.
Old Dec 7, 2009 | 09:10 PM
cmonkey713's Avatar
cmonkey713
I would check the Service Technical Bulletins for what ever year you are considering. I would consider an '08 or newer becuase of the LS-3 engine and other meaningful upgrades. Just do your homework and go find exactly what you want. Always remember, if you don't simply love the car it is not a good deal at any price. Happy hunting.
Old Dec 7, 2009 | 10:07 PM
Tally Ho's Avatar
Tally Ho
From: Out Where the Buses Don't Run, Eglin AFB/ Niceville FL
2022 Corvette of the Year Finalist -- Modified
2021 C6 of the Year Winner - Modified
2020 C6 of the Year Finalist - Modified
Only three issues with mine (06 vert currently at 15K miles):
1. Torn headliner fixed under warranty
2. Differential chatter - fluid replaced under warranty
3. Brake squeal - replaced stock pads with ceramic pads (Z51 optioned)
waxrbox's Avatar
waxrbox
Also have that fuel gauge problem. Only 5000 miles on my 06 and it's swinging all over the place. Estimated big bucks to drop both tanks to replace with a new fuel sender. Apparently a known problem, but not warranty -GM is blaming the additives in the fuel, although there is an "improved" model that will replace it.
Old Dec 7, 2009 | 10:17 PM
dads toy's Avatar
dads toy
had my 2007 for about 8-9 months.
issues:
not enough time to drive it
not enough money to mod it how I want
one low tire pressure when temps dropped from 60 one day to 20 the next. original run flats
Old Dec 7, 2009 | 10:22 PM
Rocketmanwpb's Avatar
Rocketmanwpb
08 with no real issues, had the diff oil replaced under TSB and really improved the diff chatter and car bucking at low speed.
Drive mine a grand a month and have 20,000 on it at present.
No other real issues.
Old Dec 7, 2009 | 10:24 PM
NFexec's Avatar
NFexec
issues:
hooo - boy . . . sounds like you got a lemon!
Old Dec 7, 2009 | 10:32 PM
wombats777's Avatar
wombats777
St. Jude Donor '14-'15-17-'18-'19, '21,'24-'25-'26
Popping top and squeaky brakes on my '08 with 12K miles. Otherwise flawless.
Old Dec 7, 2009 | 10:43 PM
Rowboat66's Avatar
Rowboat66
Buy a battery tender and use it religiously.
To C6 "Issues" ?
Old Dec 7, 2009 | 10:56 PM
Timothy Barth's Avatar
Timothy Barth
I guess Ihave been lucky.I have had no problems in 4 years,28,000 miles.
Old Dec 8, 2009 | 10:05 AM
miami08VETTE's Avatar
miami08VETTE
DON'T BUY ONE! ITS A NIGHTMARE CAR!!!!!!!!!!!!!!!!!!!!!
Where to start.......................
I hadn't even taken delivery and I already had a pile of add-ons for it. Then I spend a fortune on cleaning products because I just love to keep her clean and shiny. Now with 8800 miles on her, I am looking into fancy wheels and leather interior upgrades.
I am telling you steer clear. This car will cost you a fortune in the long run!
Old Dec 8, 2009 | 08:08 PM
skylarkul's Avatar
skylarkul
Too late. I'm already hooked. I just sold my 01 vert and I'm working on trading my wife's 01 coupe in on a silver 08 vert.
I went to the NHTSA site and looked up the bulletins on the C6. I started writing them down but, the list went on forever. Most of the stuff wasn't a concern. The issues about the anti-lock brakes and automatic trans 2-3 upshift are definately things to be aware of - if not worried about.
Thanks everyone for your input. As usual, you came accross with just what I was looking for.
Les
