LED tail light bulb replacement
Old Dec 8, 2009 | 11:55 PM
gr86ss's Avatar
gr86ss
Default LED tail light bulb replacement
Here's what I put on my C6. Got these from V-leds.com. I got them from the popular auction sight. Do a search for "V-LEDS RED V-STAR TAIL/BRAKE LIGHT BULBS 3157 3156 VS" They cost $70/pair. You will also need their 6 ohm resistors to prevent hyper flash.
LEFT IS LED, RIGHT IS STOCK LAMP
BRAKES ON - LEFT LED, RIGHT IS STOCK
My tail lights are tinted and the LEDs show up very well in the daytime and night time
Old Dec 9, 2009 | 01:32 AM
Xedes's Avatar
Xedes
NICE!! I saw those bulbs and was wondering how they would look. Now I know they look great. Any issues with installing they?
Old Dec 9, 2009 | 01:27 PM
gr86ss's Avatar
gr86ss
No installation issues at all. Most time consuming part was splicing in the 6 ohm load resistors, but that was a breeze also.
Old Dec 9, 2009 | 02:26 PM
SicMSP - Daniel's Avatar
0SicMSP - Daniel
Former Vendor
Do you have any pics with the tinted covers on while braking? It looks good
-Daniel
Old Dec 9, 2009 | 04:03 PM
gr86ss's Avatar
gr86ss
-Daniel
Daniel- The pix ARE with the tinted tail lights These puppies are BRIGHT!
Old Dec 9, 2009 | 10:46 PM
chevyc6z51's Avatar
chevyc6z51
nice is i hard to cut the wirers??
Old Dec 9, 2009 | 11:15 PM
gr86ss's Avatar
gr86ss
No cutting of the wires. The load equalizers come with wire taps to splice into the harness.
Old Dec 10, 2009 | 12:34 AM
LS WON's Avatar
LS WON
Is it true that the LED's drain less current than the regular factory lights?
Old Dec 10, 2009 | 12:39 AM
gr86ss's Avatar
gr86ss
Yes, that's why this installation requires 6 ohm resistors (load equalizers) with each LED added so that hyper-flash doesn't occur.
Old Dec 10, 2009 | 12:41 AM
LS WON's Avatar
LS WON
Is this install easy enough for the novice without any meters or fancy tools to do this change out?
Old Dec 10, 2009 | 12:58 AM
Knob Jockey's Avatar
Knob Jockey
St. Jude Donor '11-'12-'13-'14-'15
How/where did you mount the load resistors?
Old Dec 10, 2009 | 07:58 PM
gr86ss's Avatar
gr86ss
Absolutely!
I took pix, but can't seem to locate them. I'll have to search for them this weekend. I basically attached them to the wire harness and used tie wraps to stand them off away from the harness. Similar as you would do with spark plug wires (old school style) with tie wraps.
Old Dec 11, 2009 | 12:10 AM
LS WON's Avatar
LS WON
Absolutely!
great job. I wouldn't blacken my tail lamps with my luck I would probably get pulled over but I would like em to be as bright as possible.
Old Jan 5, 2011 | 08:19 PM
gp56's Avatar
gp56
Just ordered the lights and resistors, thanks for the tip!
Old Jan 5, 2011 | 08:41 PM
///DarkSide\\\'s Avatar
///DarkSide\\\
St. Jude Donor '12 thru '26
Pics of resistors?
Old Jan 5, 2011 | 09:07 PM
gr86ss's Avatar
gr86ss
Originally Posted by ///DarkSide\\\
Pics of resistors?
Go on the popular auction site and do a search for "6 ohm resistor"
I must have accidentally deleted my original pix.
Old Jan 5, 2011 | 10:00 PM
MikeSVT04's Avatar
MikeSVT04
Ok I am a huge nooob when it comes to wiring......So I will ask...
what is a 6 ohm resistor? lol
It would be most generous of you to make a DIY on this with pics lol. They sure are brighter and a good price to boot.
is this them? http://www.v-leds.com/Exterior-LED/B...72879-1-2.html
they are only 50 here.
now which resistor is it?
Old Jan 5, 2011 | 10:13 PM
glenB's Avatar
glenB
St. Jude Donor '08-'09 & '12, '14
Pics of resistors?
I bought the plates as well and mounted them with a rivet to the existing hole in the tub. As you can see it's upside down, but it doesn't matter which way it's wired. I bought the plates cuz they are cheap and the resistor gets hot. I wired the grounds together and ran a single wire to the bumper behind the cover.
Old Jan 6, 2011 | 12:28 PM
gp56's Avatar
gp56
Did you use one 6 ohm resistor per side or per bulb? I just ordered the bulbs and was told I only need one resistor on each side by the vendor. Thanks.
To LED tail light bulb replacement
