Ok, I just bought (from marylandspeed ) a vararam intake for my ls3, and I haven't installed it yet.
I know this a deadbeat topic, but I have been reading horror stories of vararam not sealing properly and sucking in dirt, grass, etc. So my question is, do the new vararam for the LS3 have been improved or people are still getting problems with the sealing and the quality of it?
If so, should I return it and get halltech?
My C6 is my daily driver, and I certainly would hate for an intake to ruin it
I also have a Vararam for my 05 and after 6 mos the top 1/2 did warp, I contacted them, & I received a new revised version (much thicker plastic & much stiffer) it fit perfect, & I've never had any problems again..
If you just bought it my guess is you have the newer version and should be fine... its a great product... Stick with it you won't be sorry !!
I have an older model, and the 2 sided tape for the seals deteriorated over time, and the seals shifted, but some shoo glue have them in there to stay now. The seal is perfect. On the filter clean, the seals are easily checked. I think this CAI is a Cat's Meow.
The seals are a joke, deal with them. The upgraded thicker component is better but I still think the fit is sub par. I have one and makes good power but I am not really pleased with the quality of mfg. It is true cold air unlike others.
Epoxy the seals so they don't move around. Keep an eye on it for warping. If it does, they will send you a new upper half. I had one on my C6 and it performs as advertised.
There are a few (LS3) members here that are having problems with engine surging. It only seems to be with the vararam and vette-air. I believe it's just the LS3 that are reporting this problem.
I have a really old one...my car is 4 years old now.. however, other than
re-adjusting each time I clean the air filter each winter, it's been just fine. I never ordered or pestered Vararam to get any new parts. Perhaps, in today's climate of getting freebies from everywhere I should,but, I'm not unless I really need replacement.
Regardless if it is new or old style, when it sees any heat the seals will come unglued. You must take it apart to check this.
I did see another forum member that used sheet metal screws through the plastic into the filter element to control the warping.
I live here in Texas, and it gets pretty hot. So warping would be my main issue and spending $400+ on an item that still needs to be modified for its poor quality is absurd.
The License plate interferes with the MAF sensor when it mounted directly in front of the snorkel. At least it did for me. True, at least for me, that Vararam addition caused some very minor surging and I was able to have it tuned out.
I bought 1 several months ago and it fit together perfect, a friend of mine got one about a month ago and came over so we could both complete the install...I didn't like the way it went together so he contacted Vararam and they sent him another complete unit and it was a perfect fit.
I don't think there is a system out that does what it is supposed to better + I don't feel like the system is overpriced considering it is a true CAI.
