Check Engine Light
Old Dec 11, 2009 | 06:47 PM
wxmcpo's Avatar
wxmcpo
Default Check Engine Light
Came on for the first time yesterday and I'm not sure why. Is there any easy way to check for codes like a diagnostics mode or do I have to get a scanner to try and read the code? Also is there a list somewhere of all the codes? I tried using search, but came up with very old threads only. Thanks
Car info - 2006 1LT coupe.
Old Dec 11, 2009 | 06:49 PM
Raazor's Avatar
Raazor
Goon Squad King of Battle
St. Jude 15 Year Donor
St. Jude Donor '08 thru '23
My Predator checks them and can reset them also. Loose gas cap??
Old Dec 11, 2009 | 06:52 PM
wxmcpo's Avatar
wxmcpo
Don't think so cause I filled up a couple of weeks ago and light is just now coming on. Where do you get the Predator? Is that simply a scan tool?
Old Dec 11, 2009 | 06:53 PM
Raazor's Avatar
Raazor
http://www.concoursdirect.com/diablo...-predator.html
Old Dec 11, 2009 | 07:00 PM
wxmcpo's Avatar
wxmcpo
So does that come with canned tunes for the vette as well?
Old Dec 11, 2009 | 07:07 PM
Raazor's Avatar
Raazor
No. My mechanic used it early on to fine tune the stock tune for our elevation etc...
My engine light came on this summer and I used the Predator to see what was up. The code was a misfire. It was super hot and I was running a little lean. Took care of the problem myself and reset the check engine light. It's handy to have. This way you don't have to run to the dealer every time it comes on.
Old Dec 11, 2009 | 07:09 PM
not08crmanymore's Avatar
not08crmanymore
Yes it does.It won't fix the issue but will tell you what it is as well.Any AUTO ZONE or place like that can read your vette too and for free.
Old Dec 11, 2009 | 07:14 PM
wxmcpo's Avatar
wxmcpo
Thanks. I thought they do, but wasn't sure. No Autozones out here, but I'm sure Checkers will do it as well.
Old Dec 12, 2009 | 12:21 AM
dgrant3830's Avatar
dgrant3830
Wounded Warrior Escort '11
Costco has a small code reader device that will also clear codes and its CAN enabled. Don't hold me to this, but I think it was like $30. I was going back tomorrow to buy one for my son, for Christmas. I was in there the other day and the price label was missing, so I'm not sure on that price.
Old Dec 12, 2009 | 12:32 AM
cclive's Avatar
cclive
What area of the store?....this is interesting....
Old Dec 12, 2009 | 03:44 AM
wxmcpo's Avatar
wxmcpo
Old Dec 12, 2009 | 09:25 AM
Glennm27's Avatar
Glennm27
2017 C7 of the Year Finalist
St. Jude Contributor
Just a hunch, but I'm going to guess in the Automotive section...
Old Dec 12, 2009 | 03:20 PM
dgrant3830's Avatar
dgrant3830
Ok, I bought it just now from Costco. Its a "Code Key", model 375265 and it was $34.99. Since its a gift, I'm not going to open it, but it states its good for all ODBII's and CAN
Old Dec 12, 2009 | 03:47 PM
Zymurgy's Avatar
Zymurgy
Moderator
If you have a scanner that does not provide a word version of the code, you can easily look up the code by entering it into a Google search.
Example: A search for P0021 yields a website called engine-light-help.com which offers the following:
How does a P0021 code trigger the check engine light? This code will trigger the check engine light under the following condition:
The comprehensive component monitor, referred to as the CCM, monitors the Variable Camshaft Timing (VCT) position for over-advanced cam timing. If the cam timing exceeds a maximum calibrated limit or is stuck in an advanced position, the check engine light will come on and set this trouble code.
Possible Causes:
Incorrect camshaft timing
VCT solenoid valve stuck open or continuous oil flow to piston chamber
Camshaft advance mechanism binding, or faulty VCT unit
Diagnostic Help:
This check engine light code is caused by a mechanical fault of the VCT unit or related components, so there is no need for electrical diagnosis. Possible symptoms may include rough idle, stall or hard start. Refer to manufacturer specific component tests for the VCT unit. You may also use the "Get Help" link if you need specifications or have any other related questions. Remember to refer to an appropriate manual for specific instructions.
Old Dec 12, 2009 | 04:03 PM
bksnoopy's Avatar
bksnoopy
I think you can go here and type in your code .... and get an answer.
CodeKey
Ben, OH
Old Dec 12, 2009 | 10:23 PM
wxmcpo's Avatar
wxmcpo
Got a friend who has a Costco membership so I'll have them check if we carry these out here.
Thanks for all the replies so far. Appreciate the inputs and information.
Old Dec 13, 2009 | 07:55 PM
wxmcpo's Avatar
wxmcpo
Well it actually did turn out to be a loose gas cap. Got in the vette last night and check gas cap was displayed once the car started up. Opened up the gas door and sure enough the gas cap was not tightened on. Tightened up the gas cap and the check engine light went off. Thanks for the replies.
To Check Engine Light
Old Dec 13, 2009 | 08:18 PM
Mad*Max's Avatar
Mad*Max
This is strange that it would happen after two weeks
Old Dec 13, 2009 | 11:40 PM
wxmcpo's Avatar
wxmcpo
Yeah that is what I was thinking and why I did not think it was the gas cap initially. I did have a hard time getting the cap back on though. Kept sounding like there was air being pushed from the tank or like it was trying to get a seal or something.
Old Dec 14, 2009 | 07:36 AM
Mad*Max's Avatar
Mad*Max
Could your gas cap be defective?
