For those who have installed NPP exhaust. Seems to me that anytime you accelerate you will loose vacuum, since the vacuum source is directly from the intake, and the butterflies will open. Could you explain why this doesn’t occur or does it?
From: The Great Pacific Northwest...........I carry a gun cause a cops too heavy.
When you open the throttle on any engine the vacuum drops to O. With the NPP the vacuum keeps the valves closed except during acceleration, then the vacuum drops off and the valves open.
Hope this helps answer your question.
If that is the case, then how come an electrical divice hooked up the the fuse box will leave them open?
When you start a C6 with NPP the butterflies are open and then close as soon as there is enough vacuume to close them. At around 2800 rpm's an electric silenoid begins to kill off the vacuume as the butterflies open up. Pull the fuse on the system and the butterflies stay open all the time.
Sorry guys, you didn't read the question very well. The question concerns NON FACTORY installed NPP. If you run the vacuum line dirrectly to the intake, when you accelarate and the vacuum drops the valves should open no matter what rpm the motor is at, isn't that correct, is that what is actually happening.
I have it... installed on my 06, NON-FACTORY... what you do not understand is... it takes Vacuume to CLOSE the flaps... so if vacuume goes to Zero... they will be OPEN... You need a Retro-Fit NPP in a box... it is great...you can have open or closed ANY time you want. The NPP controls the vacuume. Vacuume does not fall to Zero, under hard acceleration, and they stay closed, if you set it to close... You open when you push the buton to allow vacuume... It is not hard to get used to
I have the B&B Fusion exhaust. It came with a vacuum reservoir that mounts in the space behind the passenger side rear tire. It holds enough vacuum to keep the exhaust in quiet mode even at full throttle. I would think the factory system would have some sort of reservoir as well.
This is good info, I installed the NPP exhaust and to answer the OP's question, the valves don't modulate with engine vacuum but there are certain conditions like hard acceleration for a longer period of time where they will open slightly giving a low growl which I happen to like. I have not seen any posts of this being an issue so I assume that it must be a rare occurrence as I've experienced.
The valves vacuum actuators must require a low amount of vacuum to stay closed and only crack open in certain instances that I described above. I guess a vacuum reservoir could always be added, if desired, if anyone finds it annoying.
If you are going to add NPP to a non-NPP car, I think the best solution is to use the "NPP In A Box". This mounts in one of the rear storage bins and has its' own vacuum pump. You just need a 12 volt source and then run a short length of tubing over to the exhaust valves. No need to route a tube all the way up to the engine. Connected directly to the engine, the valves would be at the mercy of what the engine is doing. With the NPP In a Box, you can open and close the valves at will by just pressing the button on the included remote.
I installed Z06 mufflers and ran the vacuum line to the intake manifold. You partially correct, in that when you get on it, the valves will open, but unless you stay WOT the entire time, the valves will start to close. So in a 1/4 mile run at the strip, yes they will stay open, but on the street as soon as you back off just a bit, they will close. Ed "Pipedreams" has some hard numbers as to the vacuum required to close the valves but I don't remember the numbers.
I used Sunset Orange's controller for two reasons. I did not want to drill holes in my car body, and two, I wanted the flaps to open at a preset RPM, much like the stock system.
Sorry guys, you didn't read the question very well. The question concerns NON FACTORY installed NPP. If you run the vacuum line directly to the intake, when you accelerate and the vacuum drops the valves should open no matter what rpm the motor is at, isn't that correct, is that what is actually happening.
As noted in replies above, it wouldn't be advisable to connect the non-factory NPP directly to the manifold as you noted, it would be at the mercy of the variations of vacuum pressure under acceleration. The factory system uses a check valve and solenoid at the manifold as well as an accumulator mounted near the mufflers like the one mentioned in the aftermarket bi-mode exhaust. Both can be seen in this illustration of the factory system.
The NPP in a box system available aftermarket, provides it's own vacuum source which eliminates the need to tap the manifold for a vacuum source and it allows that source to be controlled electronically from a supplied remote.
This is not true. You need vaccum from the motor to make the box work. If you doubt it go to the website and there are instructions on how to install. There are two nipples on the box one for the vaccum from the motor the other goes to cans on the muffler tips on the exhaust. The 12 volt source is under the passenger floor board using the heated seat fuse. The valves work like the stock system meaning when you shut the car off the valves go to the open position, When you start the car the valves close and stay that way till you open them with the fob.
To be honest... you can have all the theorys you want...
But, I like many, many others here, I have installed NPP on non-factory installed car... I used NPP In-A-Box, that connects to engine vacuume. THERE ARE NO ISSUES... It is BETTER on a Non-Factory car, than on a factory car... as I CAN keep the flaps closed above 3500 RPM, which a factory car can't do....
