NPP Question
Old Dec 17, 2009 | 02:55 PM
Jakeross's Avatar
Jakeross
Default NPP Question
Do the NPP pipes have a larger diameter than the standard C6 exaust?
Old Dec 17, 2009 | 02:58 PM
beav626's Avatar
beav626
The tips are larger but the pipes are the same 2.5"
Old Dec 17, 2009 | 03:54 PM
LS2-Zomb!e's Avatar
LS2-Zomb!e
Old Dec 17, 2009 | 04:03 PM
j_digi454's Avatar
j_digi454
The tips are 3 1/2 inches versus the stock tips which are 2 1/2 inches. veav626 is correct in that the pipes are 2 1/2 inches in both the stock and NPP systems. The larger tips are awesome looking and fill out the back valance nicely.
Old Dec 17, 2009 | 06:08 PM
offthehook1's Avatar
offthehook1
Agree with all and.......it is a lot of fun!!
Old Dec 17, 2009 | 06:23 PM
mcc978's Avatar
mcc978
St. Jude Donor '10-'11-'12-'13-'14-'15-'16-'17,’18,’19
If you are thinking about having an NPP exhaust installed on your vette, I say go for it you will love it. You should also get the mild2wild controller.
Old Dec 17, 2009 | 06:28 PM
GQMGT's Avatar
GQMGT
If I'm not mistaken the pipes on 2009 & 2010 NPP are larger. 3 inches
2008 NPP were 2.5 inches
Old Dec 17, 2009 | 07:11 PM
beav626's Avatar
beav626
intresting...
Old Dec 17, 2009 | 07:38 PM
j_digi454's Avatar
j_digi454
I'm not sure that is correct, it's possible but I'd like someone to confirm.
Old Dec 17, 2009 | 11:22 PM
Vegas Panton's Avatar
Vegas Panton
Default Npp
The exhaust inlets for the standard muffler and NPP are both 2.5 inches; however, the standard muffler has only one outlet which is split into 2 and the NPP muffler has 2 separate outlets. As a result it flows better. Also starting in 2009 the muffler pipe that goes up and over the axle is bent slightly different due to a differential cradle upgrade in the 2009 model and newer. As a result you would want the newer X pipe to with it.
Old Dec 18, 2009 | 01:34 AM
Mike's LS3's Avatar
Mike's LS3
Also, my 08 NPP exhaust tips measure 3.5 inches in diameter.
Old Dec 18, 2009 | 09:41 AM
haljensen's Avatar
haljensen
The big difference between NPP and standard mufflers is the muffler oulet(s). The standard muffler has ONE less than 2.0" outlet that Y's into two tips, the NPP muffler has TWO outlets, the inside @ 2.4xx" and the outside @ 2.1xx". More than twice the flow available from the NPP.
Old Dec 18, 2009 | 11:36 AM
Jakeross's Avatar
Jakeross
Thanks Guys. I did get some 08 takeoffs put on my 08. After I got home I thought they looked bigger and could not remember to size of my takeoffs. I love the sound and all my friends are jealous of my new toy.
Old Dec 18, 2009 | 04:41 PM
B-STOCK's Avatar
B-STOCK
St. Jude Donor '14-'15, '17, '19
Also, does the 09 NPP have a X pipe insted of a H pipe?
Old Dec 18, 2009 | 06:42 PM
sranger's Avatar
sranger
Yes....
Old Dec 18, 2009 | 06:47 PM
B-STOCK's Avatar
B-STOCK
Originally Posted by sranger
Yes....
Do all the 09s have the X pipe or just the NPP? Thanks
Old Dec 18, 2009 | 08:13 PM
C6NRED's Avatar
C6NRED
All.........but the Z06 pipes are MUCH bigger than the NPP's:
To NPP Question
Old Dec 19, 2009 | 11:29 AM
beav626's Avatar
beav626
I believe that all LS3 cars have the X pipe
Old Dec 19, 2009 | 01:19 PM
dkrhardy's Avatar
dkrhardy
AND .... the Z06 tips don't have those goofy perforations! J/K
Old Dec 19, 2009 | 01:39 PM
AtHomeSoda's Avatar
AtHomeSoda
Default Ah...
The 4 Tips on NPP are 3.5 inches each... which is the same size as ZO6 Bi-Mode.
If by pipes you mean the 3" supply side on ZO6, that narrow down to 2.5" before the muffler , instead of the 2.5" on NPP... yes.
Also... the NPP, has a Solid pass through pipe INSIDE the muffler, instead of the Preferated pass through on the ZO6, so the sound does not get muffled.
Happy Holidays!
