Why Use Jacking Pucks???
Traction for one....... Do you really think a set of Eagle F1's provide the same kind of traction as say a drag radial? Are you going to try and say all tires provide the the same traction and wear as others
I'm not even going to touch the Aveo comment. If you want to try to put them on the same level as a corvette be my guess.
Make all the analogies you want. The fact is no one has yet given even the slightest argument how a $60 aluminum jacking puck is of better performance, quality, or whatever then a piece of wood or a peice of rubber in this case. I'm sorry if you guys that spent $60 got had.
Really? So you don't see the direct analogy between a Corvette simply being a mode of getting from point A to point B, which you can do just as easily in an Aveo? Are you really that thick? Because it's exactly why some purchase $60 metal lifting pucks instead of $1 hockey pucks...they both perform exactly the same task, just one costs a lot more and looks nicer.
I think it's pretty clear you don't have the ability to support your inane position...so I'll leave you be. Enjoy your bliss.
No I am not that thick and no my position is not insane.
the point where the puck goes is the chain point for the transfer truck to chain the car down for transport, it just happens to make a great spot for jacking
How does this post about jacking pucks have anything to do with me driving my car and you feeling safer? Maybe I made this post just to see people get pissed off or maybe I did it just to give some people a few other ideas
It would not be a good ideal to try and jack a corvette up by the trans. I assume you mean the rear craddle? My lift has round plastic pads that work perfect for lifting the vettes in the proper position.
1) Neither rubber pucks, nor a block of wood have tensile strength. Neither one was engineered to lift the weight of a vehicle. Over time, both WILL crack / fail, and subject your car to damage by your jack. Who wants to risk danaging your rocker panels?
2) Rubber pucks and blocks of wood do not necessaily fit into the recessed area on the frame, and hence, wind up LIFTING the car with the rocker panel sandwiched in between the frame and hockey puck or block of wood. Again, it's just a matter of time before you are subjected to a cracked rocker.
3) Neither a rubber hockey puck, nor a block of wood are designed to lock in place on the frame. This means, you are not guaranteed the rubber hockey puck or block of wood is in the proper location. Again, you risk cracking the rocker panel.
4) If you use a rubber hockey puck, and drill it out for Home Depot hardware, you are causing undue stress on the hockey pucks, which will lead to premature stress fractures. In addition, the metal hardware will (at some point in time), scratch either your paint, or frame.
5) The use of steel jacking pucks is an albatross. They are way too heavy, and can scratch your paint or frame. Aluminum pucks are lighter, buy can still scratch. Plastic and delrin are lighter, but they are not resilient, and hence, do not seat (or "bite") into the jack.
6) On the other hand, locking POLYMER jacking pucks have high tensile strength ... provide *bite* into the jack, and do not scratch the paint or frame. Polymer pucks are about the same cost (+/-) as compared to other manufactured jacking pucks.
There are many ways to skin this animal. If you want to save money up front, and don't mind risking a failure (and rocker damage) ... go ahead and use a ice hockey puck or block of wood. However, the safest (locking) method, which also provides anti-slip measures (*bite*) comes down to Polymer jacking pucks. The best ones I have seen are sold on CF exclusively by Dennis, at Double D Mods (CF vendor). They are available for all C5's and C6's (including the Z06 - thought not sure about C6 ZR1).
The pad on your jack may be padded but it might make contact with the rocker, and crack it. The puck, as best I recall, contacts only the frame rail and kind of locks in place with an attached chuck.
http://www.bugmanweb.com/c6/c6index.html
In addition to the jacking puck ONLY touching the frame ... and aside from the jacking puck *locking* into place ... hydraulic floor jacks that do not have a similar size "pad" permanently secured to the jack are likely to slip (either the pad slips / or falls off ... then the metal jack hitting the undercarriage of the car will not be a good situation!
Another guy made his own pair of wood ramps that would let you drive the whole car onto.
I know what you are saying: jacking pucks are silly because it takes nothing to do it yourself. I bought some pucks on recommendations on these forums for 35 bucks that snap in and stay locked. I don't think they were worth 35 but they do serve the purpose.
Life is about choices, I guess.
Be sure to use 87 octane. That will save another 20 cents!
$60 is nothing, can't even eat out for that.
I understand some people have damaged their rockers and maybe this is why. What I don't understand is this. If you jack the car in the right spot there is plenty of clearance for the pads on a lift or for the cup on a jack.
Worst case scenario you can accomplish the same thing with a small 2x4 block which can be had for free.
I'm sorry but jacking pucks just seem like a scam to me. Are people that lazy that they can't jack a a car up properly these days or are they that gullible they really think jacking up a corvette can't be accomplished without these?
I guess the guys that make their own are ok. A few hockey pucks and eye bolts are cheap. Those of you who are spending $60+ on these what are you thinking?
Jack
The set of pucks cost me $17., too cheap to bother saving $10 to make them myself. The BMW pucks are relitively expensive, but they lock into place without ratteling when driving.
Ya pays your money or ya takes your chances. There are many places one can pick and choose to save money, my pucks are not one of them.
