nav or not
Old Dec 25, 2009 | 11:45 AM
hdman 49's Avatar
hdman 49
Default nav or not
Hello members i have heared that the stereo in a c6 sounds better with out nav is that true? thanks
Old Dec 25, 2009 | 12:17 PM
bearman95's Avatar
bearman95
We have the nav and it sounds good to us. Also have a bose system in our Cadillac STS with 15 speakers and the vette sounds as good as the STS but not as good as the Audiophile system that we have in our Ford King Ranch truck but the truck has a huge factory subwoofer under the rear seat.
Old Dec 25, 2009 | 08:55 PM
BSE1956's Avatar
BSE1956
If you want good sound. skip the nav, rip out the Bose or base system and replace with a Kenwood. The whole Bose system is worse than bad. It's actually quite pathetic. There are LOTS of threads this subject.
Old Dec 25, 2009 | 08:59 PM
VET4LES's Avatar
VET4LES
I have the NAV system and I'm not happy with the sound. Our last car was an Infiniti with the Bose system and it was great. I'm very disappointed with the C6 Bose.
Double D Mods's Avatar
0Double D Mods
Former Vendor
St. Jude Donor '12-'13
I have Kenwood and Pioneer install packages available as well.
http://www.doubledmods.com/DOUBLE-DI...-UNITS_c12.htm
Old Dec 25, 2009 | 09:06 PM
pentavolvo's Avatar
pentavolvo
Cruise-In IX Veteran
dont waste the money on the nav at least in my opinion
also the nonbose cars sound better then bose cars in my opinion yes crazy i know
i would get a non bose non nav car, add an aftermarket nav later on if you want
Old Dec 25, 2009 | 09:12 PM
CyberC6's Avatar
CyberC6
My base C6 system sounds WORLDS better than a vette with the Bose/Nav system.
Old Dec 25, 2009 | 11:40 PM
phileaglesfan's Avatar
phileaglesfan
I didn't go with the NAV because I heard the sound is not as good as non-NAV, there is no traffic feature on the OEM NAV, you delete a 6 disc CD changer and you can't see the NAV if the sun is shining on it anyway. So if you life in the middle of no where, are happy with XM/FM/AM and drive in the dark then you'll be very happy with it.
Old Dec 25, 2009 | 11:45 PM
need-for-speed's Avatar
need-for-speed
CI 1-4-5-8-9-10 Vet
St. Jude Donor '03 thru '10, '17
Many here have reported the same - Nav stereo doesn't sound as good. While that the Bose isn't as good as it should be, I don't think the base system sounds better than the Bose. We have the Nav and Bose in our Tahoe.
To me, it's an easy decision. Regardless of whether ot not you think one sounds better than the other, I would not get the Nav simply because it is WAY overpriced.
I like my Garmin just fine, and if I ever were to upgrade to a kickass aftermarket system, it's that much less $ down the drain.
Old Dec 26, 2009 | 07:49 AM
FortMorganAl's Avatar
FortMorganAl
From: Currently somewhere in IL,IN,KY,TN,MO,AR,MS,AL, or FL
The answer is to go to a dealer and listen for yourself. But I would never have a Corvette without the nav. That's because the nav is so good compared to the aftermarket units. No aftermarket unit integrates with the car like the factory nav. None display on the HUD.
So, are you buying the car for the stereo in which case there are many better sound systems or are you buying it as a complete package of features that happens to include a stereo that is pretty good?
Old Dec 26, 2009 | 08:15 AM
BearZ06's Avatar
BearZ06
St. Jude Donor '09 thru '17,'22 thru '26
If you are of the younger generation or are a real audiophile, you may not be satisfied with the nav/Bose system. For me it's fine. I did change out the Bose door speakers to Boston Accoustics which improved the sound considerably. The worst thing about nav is the cost and maybe not quite the sound of a non nav system. The best things are looks, resale, touch screen controls (cd song lists and control) and most important is the ability to use the Ipod PAL interface which gives you 1000's of songs at your fingertips.
Old Dec 26, 2009 | 08:26 AM
beepster's Avatar
beepster
Sound system w/ the NAV sounds OK to my ear....it's the NAV that sucks....
Old Dec 26, 2009 | 05:54 PM
Topas's Avatar
Topas
If you want to have an OEM nav with a better sound, one option is to change the Bose amp and speakers and eventually add a subwoofer. A lot of threads exists in the Audio section about this subject.
To nav or not
