Not sure the proper name but its the bottom half of the front wheel well.Kinda hard to see in the pics but on the passenger side it is cracked looks like from scraping.Is this common?Can I buy a used one fairly cheap from someone that may have did a wide body?Any advise would be appreciated
it looks like (but hard to say for sure from the pics) its the inner fender well plastic and thats no big deal but it also looks like the floor pan might also be cracked. get us sum more pics
If this had been July, I would have given you one. I threw away a pair when I moved. Check with someone doing a wide body, as you replace (rear) the inner fender when you do the wide body.
You can buy a new one from Gene Culley at GMPartsHouse.com
