Best Replacement Battery?
Old Mar 12, 2010 | 11:47 PM
  #121
LS WON's Avatar
LS WON
Originally Posted by Brutus 08 Coupe
I just checked them. Good-to-go. FOBs are away from the car when not in use. I did finally go out and attach the Battery Tender Jr's permanent battery attachment (like I should have done earlier). Now I can at least recharge the dead battery (if that happens again) without climbing through the trunk...
I drive my 2005 once a week or start it up if I don't drive it and luckily I have not had to use a battery tender and have no problems with battery.
Is it ok to have tender hooked up to battery and battery is still connected to car?
Old May 15, 2010 | 06:35 PM
  #122
humvet's Avatar
humvet
Old May 15, 2010 | 07:04 PM
  #123
jackcasa's Avatar
jackcasa
Originally Posted by goatts
You can't go wrong with OEM.
I had to replace the one in my '05 after 4+ years and went with an AC Delco. Keep a trickle charger on it when not in use and no problem.
Old May 15, 2010 | 10:13 PM
  #124
humvet's Avatar
humvet
Couldn't find an OEM, an Optima or a Diehard today and I needed a battery.
Went with a Duralast from Auto Zone - three year 100% warranty. Will give it a try. Got 5 years from the original with quite a few recharges.
Old May 16, 2010 | 05:10 AM
  #125
LS WON's Avatar
LS WON
If it lasted this long it's good like the original factory I am still using with no battery tender and never charged but driven at least once a week. Hopefully the new batteries made today are as good or better than their original counter part from 2005.
Old May 16, 2010 | 01:18 PM
  #126
filmjay's Avatar
filmjay
St. Jude Donor '10
The East/Penn manufacturing facility isn't far from me. I'm picking up a Deka in the next week or so, straight from the manufacturer.
Old Mar 14, 2015 | 10:56 PM
  #127
lar66BB's Avatar
lar66BB
Originally Posted by saplumr
You're a lucky dog on the factory battery thing. My charger is fully auto trickle and I leave it on for probably 4 months.
Old Mar 15, 2015 | 08:45 AM
  #128
2vettes's Avatar
2vettes
Absolutely ok
