nav screen ?
Old Jan 11, 2010 | 03:59 PM
budgreen3564's Avatar
budgreen3564
Default nav screen ?
yesterday, I drove the car to get it hand washed. the nav screen was completely out. no display of nav, radio, clock. when I got in the car to go back home, it was working again. we had low temperatures of 14-15 the two nights before. is this another electrical gremlin, or could the cold affect it.
Old Jan 11, 2010 | 04:05 PM
calemasters's Avatar
calemasters
I believe it is normal operation for LCD displays. The are very dark when cold. Display will start to brighten around 40 degrees F.
Old Jan 11, 2010 | 04:08 PM
budgreen3564
it did finally get in the 40's yesterday
Old Jan 11, 2010 | 04:24 PM
waldow's Avatar
waldow
St. Jude Donor '09
Had the same problem. Everything works but no screen, touch screen works if you know where to touch-- but blank. module replaced under warranty-- no hassles
Old Jan 11, 2010 | 05:30 PM
budgreen3564
thanks
Old Jan 12, 2010 | 06:22 PM
Gearhead Jim's Avatar
Gearhead Jim
St. Jude Donor '13
Temps down in the 20's in our garage, 2009 Nav screen stays black (or at least too dark to read) for a couple of minutes after startup, then looks normal.
I don't remember our 2006 doing that.
Old Jan 12, 2010 | 06:24 PM
PJRed2008's Avatar
PJRed2008
Mine does this when its cold. I am having the nav firmware upgrade done Saturday to see if it helps.
Old Jan 12, 2010 | 08:28 PM
Cdn Z06 Mike's Avatar
Cdn Z06 Mike
Some of the BMW Nav screens have heaters and coolers in them to protect the screen in very cold and very hot temps for this very reason.
Old Jan 12, 2010 | 08:30 PM
BAD_TCR's Avatar
BAD_TCR
Mine will do this even without the cold. just random times, nothing on the screen, touch doesnt work, nothing..blank. Turn off ignition, restart, and its back.
To nav screen ?
