tiny rocks
Old Jan 14, 2010 | 06:04 PM
Chris3's Avatar
Chris3
Default tiny rocks
Hi Guys
Just got home with my new purchase...2009 vert..triple black Z51
Can someone tell me how to clean out the creases just behind the driver/passenger door...just above the rockers.
Seem to see some very small rocks stuck in the crease and cannot pop em out. Can I remove something to get these out?
Thanks guys.
Old Jan 14, 2010 | 06:05 PM
pewter99's Avatar
pewter99
St. Jude 15 Year Donor
Pilot of Beer Force 1
Tampa Regional Coordinator
CI 4-5-6-7-8 Veteran
Organizer St. Jude Fundraiser
I believe in the Beer Fairy
water will rinse some out but I do not advise trying to force them out....
Old Jan 14, 2010 | 06:22 PM
Sunset 05's Avatar
Sunset 05
Pull your rear wheel, and wheel housing shield and there is a bolt you can undo and the fender will flex slightly so you can clean it out.
Old Jan 14, 2010 | 06:27 PM
kmthor00's Avatar
kmthor00
I know this might sound crazy but it worked for me, took a long nose pliers & pinched / crushed the little pebbles, they simply desintigrated, it works just be cautious!
Old Jan 14, 2010 | 06:28 PM
OneBadZ06's Avatar
OneBadZ06
St. Jude Donor '08-'10
Happens on all C6 platforms. Mine as well get used to it.
Old Jan 14, 2010 | 06:32 PM
LMB-Z's Avatar
LMB-Z
I know this is going to sound stupid, but it works. Just take your hand and hit the panel, don't have to hit it very hard. Rocks and sand will fall out.
Old Jan 14, 2010 | 06:36 PM
Swiftrider08's Avatar
Swiftrider08
I have used a dental pick on a few that were stuck pretty good. I have not had this issue very often but it is reported here by many.
Old Jan 14, 2010 | 06:37 PM
dpigguy's Avatar
dpigguy
do a quick search on this and you will find quite a few discussions on how to prevent these in the future as well. whatever you do, do it carefully.
Old Jan 14, 2010 | 06:55 PM
Red Rochester's Avatar
Red Rochester
Veteran: Coast Guard
You can remove the fender well and add weather stripping to resolve the problem.
Old Jan 14, 2010 | 07:11 PM
RicK T's Avatar
RicK T
PM sent with link.
Old Jan 14, 2010 | 07:14 PM
Chris3's Avatar
Chris3
Gotcha guys...Iam good now.
Thank-you
Old Jan 14, 2010 | 08:37 PM
Quasar21's Avatar
Quasar21
http://forums.corvetteforum.com/c6-c...ml?forum_id=74
Old Jan 14, 2010 | 08:53 PM
Chris3's Avatar
Chris3
Old Jan 14, 2010 | 09:20 PM
Marc V.'s Avatar
Marc V.
Old Jan 14, 2010 | 09:56 PM
breakskeet's Avatar
breakskeet
Did this, problem solved!
cheers!
To tiny rocks
