On Star Module Removal
From bksnoopy on the CF. 7/14/08
OnStar is EASY to disable....
a) Remove the one and only fuse for OnStar
b) At the back of your car, open the right rear storage compartment, the OnStar module is in there, you might have to pry up the carpet to get at the VCIM (OnStar Module).
c) UNPLUG connectors J1, J2 & J3 ...and UNPLUG the 2 antenna connections. One antenna is for OnStar's GPS signal. (If you have a 3LT car w/NAV, don't worry, the NAV has it's own GPS antenna!) The second antenna is OnStar's Cellular Phone Antenna.
d) The 4th connector, J4, is part of your car's Computer Network Data Bus. LEAVE that connector alone! If you unplug J4, your engine will not start. If you REALLY want the OnStar module out of your car THAT bad, you NEED to install a termination resistance! The "easiest solution" is to just leave the OnStar module in the car with J4 connected! The OnStar module will be TOTALLY DEAD!!
Thanks,
Bodie
