I end up changing mine for the track at every event as I want to keep my boiling point as high as possible. There is a pretty good graphic on this page for AMSOIL DOT 3 brake fluid that shows what happens to the boiling point over time (note that I use their DOT 4 for the track): AMSOIL Series 500 High Performance DOT 3 Brake Fluid
I follow the maintenance interval from the Nissan and Acura owner's manuals I have. They both say change brake fluid at 3 yrs regardless of mileage. Rusting out the brake master cylinder (from water built up in the brake fluid) is rather costly. Why doesn't GM put this maintenance item in their owner's manual? Beats me. Do they have non-hygroscopic fluid? Doubt that. Maybe it's a way to sell more GM brake parts down the line. The procedure itself is straight-forward. I was intimidated the first time I did it, but with all the help out there on the internet, it was easy. Just follow directions (like the order of bleeding the lines...it's not always the furthest bleeder valve away from the master cylinder first.) Of course, if you trade your car within 5 yrs, you can "follow the owner's manual" and let it be someone else's problem later...
Yes...juts don't pump the pedal with the lid off or the tank empty.
I did this on my ranger first lol. I sucked out and re-filled the reservoir with fresh brake fluid every three days or so or until the fluid "browned" up. I used a tall bottle of fluid. After about 2/3rd bottle the fluid stayed clean. Truck had 60k on it and it made a huge difference in pedal modulation.
I did it in the Vette at 15k...tall bottle just because....
If you have the OEM Dot 3 fluid in the lines, is there any danger in using the "turkey baster" to change fluids to a Dot 4 fluid (i.e., any harm from slight mixture of the DOT 3 and DOT 4 and/or different brands of fluids)?
Additional Question: the article posted earlier recommended AMSOIL or Castrol brake fluid... does anyone know a retailer who stocks these on the shelf? Is there any significant differences between brake fluid manufacturers in terms of quality?
DOT 3 and DOT 4 (and DOT 5.1) are completely compatable. They are all polyglycol-ether based.
Any name brand brake fluid is good for everyday use.
Uh oh, looks like I'll have to change my fluid this year as it's my 3rd year of ownership.....but, I'll upgrade the braking system with Z06's at the same time. Thanks for reminding me.....more money to spend that must be done...
What do others think about the "Turkey Baster" method (changing the brake fluid by pulling it from the reservoir with a turkey baster)???
I have never heard of doing this and find it interesting, especially if you want to save a little money...
Thoughts???
It is to start out with clean fluid coming out of the master cylinder to the individual wheel cylinders, remember to refill with clean fluid before starting to bleed.
Thoughts???
It can't hurt anything, although it won't provide as much benefit as the Ranger clutch fluid procedure since the brake fluid does not circulate - it only goes "back and forth".
If you decide to do it, buy a "Mixer Miser" at Walmart. It's by the gas cans. Cost is $3 and it's much better than a turkey baster. I have one for the Ranger clutch fluid change method.
Even if it wasn't compatible the transfer would be minimum as I am only using the syringe to pull the fluid. I pour the new fluid with a funnel.
Answering several questions posed above:
- DOT 3 and DOT 4 are compatible as they use the same base fluid - independent of vendor. I use the turkey baster method all the time. For example, a few weeks ago I sucked out the GM stock fluid in my wife's Trailblazer and added AMSOIL's DOT 3 fluid.
- There is a big difference in the fluids of various vendors. Best bet is to compare wet and dry boiling points. The minimum dry boiling point for DOT 3 brake fluid is no less than 401°F, and the minimum wet boiling point is 284°F. The wet number is probably a better comparison point for most street cars given how long the fluid sits in the car, but for the track I normally would consider the dry boiling point as most track day guys bleed their brakes very often. As a comparison to the above minimums for DOT 3, the AMSOIL DOT 3 has a dry boiling point of 525F and a wet boiling point of 313F.
- If you can't find a local vendor, I can buy via AMSOIL and have it shipped directly to you. PM me if interested and I'll give you the best price possible.
I hate to sound dumb, but what is the "Ranger clutch fluid change method" ? Why the name "Ranger" ?
