Shift and brake boots
Old Jan 23, 2010 | 12:46 PM
CORVETTE2009's Avatar
CORVETTE2009
Default Shift and brake boots
Maybe it's just the 3LT interior, but the shift and brake boots are a little on the cheap side. I have the ebony interior and plan to just upgrade them in the same color.
Any suggestions on who sells the best replacement leather boots?
Old Jan 23, 2010 | 12:57 PM
Trout-44's Avatar
Trout-44
St. Jude Donor '10-'11, '14
Default Installed mine
Thought the base was cheep ( inexpensive looking)
Replaced mine with parts for Forum Vendor DS Vetts..Great people outstanding products
Here is mine on my 2009
Old Jan 23, 2010 | 12:59 PM
CYOUL8ER's Avatar
CYOUL8ER
Definitely DSVettes
Old Jan 23, 2010 | 01:02 PM
QUAKEJAKE's Avatar
QUAKEJAKE
And can we mention the Cobalt steering wheel?
Old Jan 23, 2010 | 01:37 PM
mpuzach's Avatar
mpuzach
DSVettes all the way. I went with their boots, e-brake handle, and shifter ****. They make a huge difference in the look and feel.
Old Jan 23, 2010 | 01:54 PM
GotVett?'s Avatar
GotVett?
DS Vettes here also.
Old Jan 23, 2010 | 02:13 PM
talon90's Avatar
talon90
Cruise-In 11 Veteran
NCM Ambassador
St. Jude Donor '05-'06-'07-'10
Down South Vettes, hands down. I swapped out my shift ****, shift boot, ebrake handle, ebrake boot, center console cover, door pulls, sun visor and steering wheel. All with DSV leather. Well worth it and the quality is amazing.
http://www.dsvettes.com/new/
Old Jan 23, 2010 | 02:35 PM
MARSC6's Avatar
MARSC6
I went with redlineggoods.
http://forums.corvetteforum.com/c6-p...-your-car.html
Old Jan 23, 2010 | 04:35 PM
Carnac's Avatar
Carnac
I installed a DSVettes shift boot, e-brake boot, and grip. They are excellent (took a while, but nice quality - web site sucks to try to order from, just call them).
Also added a white Hurst shift ball from Nakidparts (a former CF vender).
Old Jan 23, 2010 | 04:40 PM
nwc6's Avatar
nwc6
Might as well replace that center console lid while you are at it..Your elbow will thank you on longer trips..
DS vettes work:
Old Jan 23, 2010 | 04:42 PM
JERGENSEN LS3's Avatar
JERGENSEN LS3
From: New Jersey - National Corvette Museum Member '08, '09, '10, '11, '12
I too am a big fan of DSVettes....
You may want to consider going w/ a different color stitching,( other than black ) I really think it makes the ebony look sharper.
Old Jan 23, 2010 | 04:58 PM
Jim Nebraska's Avatar
Jim Nebraska
I had the same feeling. Another Forum membr sold me his CarSkinz boots (****fter and e-brake). They make a big difference!
Old Jan 23, 2010 | 05:04 PM
johnodrake's Avatar
johnodrake
Moderator
Another vote here got Gerardo and his gang at Down South Vettes. Most of my interior has been done with DSV leather:
Old Jan 23, 2010 | 08:24 PM
porschebreath's Avatar
porschebreath
Stupid question , but how do you remove the E- brake handle?. I took out the screw then pulled, it went up about an inch. What am I doing wrong?. Thanks
Old Jan 23, 2010 | 08:45 PM
JERGENSEN LS3
Once you have removed the screw at the base, then pull the handle up and forward.
The handle will slide off along w/ the release button.
To re-install, slide handle on, tighten screw, and snap release button back on until it clicks.
Old Jan 23, 2010 | 09:03 PM
porschebreath
Thanks, I was really pulling pretty hard. I guess I will go for it and really yank. Thanks
Old Jan 23, 2010 | 09:38 PM
JERGENSEN LS3
You should not have to go crazy...just nice hard pull and it will slide off.
Once the set screw is removed, it is the top release button that is actually keeping the handle on.
So by pulling up and forward on the handle you are actually popping off the button.
Old Jan 24, 2010 | 12:21 PM
Jim Nebraska
Mine was a lot harder to pull off than I expected. I took the roof off to get a bit more leverage. Also, when it comes off, things travel pretty fast...I hit my mirror the the handle, but luckily nothing broke.
To Shift and brake boots
