Clear cover for headlights
Received 2,481 Likes
St. Jude Donor '15
"In honor of jpee"
Edit: I didn't see calemaster's post. I do believe GM's recommendation/suggestion. However, I know how difficult it is sometimes to life-cycle materials in a lab, out on the lawn or on a computer.
What we have here is some "space age plastic" (to add a little humor to a serious conversation) that has to work under very high internal heat from the HIDs, ambient temps, minus 30 degree weather, and all the chemicals in the air----forever! Or, at least for as long as we own the cars. That's not easy to do.
So, the best way to determine what is at fault is not to alter the lens at all, except for cleaning. That's GM's take on it. Some coverings MAY work due to a lot of different conditions as RLsebring says above. And some may work for only a short time. Or very short time. Or it could be the plastic lens cover itself.
Whatever it is, I guess if you want to prevent some of the hazards of the road from clouding/pitting the lens cover, WE cover the lens at our cost if something happens beneath the covers we put on. And just so I'm clear on it, for my own sake, I know the cost of a replacement "lens" is very expensive, per unit.
My 2005 has a clear film protectant and it has since one month after it rolled off the lot in October of 2004.
Make sure you get a thin film, too thick and it can cause overheating. Make sure whoever does the install knows what they are doing, the wrong surface preparation (too much alcohol, too many solvents) and the lens can develop crazing. Knowing what I know now, I wouldn't likely put the film on a new Corvette but I have had great luck in my nearly 30,000 miles with the covers on.
I know...OLD THREAD, but same subject
Wanting current thoughts on having TINTED PPF (Xpel,3M, Suntek, ??)
applied to my Head Lamps & Fog Lamp Lenses ????
I used to polish my lens with a light scratches remover compound and they look like new
