battery terminate
Old Feb 3, 2010 | 04:45 PM
wratran's Avatar
wratran
Default battery terminaL
My positive terminal got corroded. While trying to losen the nuts to clean it, the stud broke off.
What is the best fix to replace the terminal? I want to avoid replacing the entire positive cable.
Old Feb 3, 2010 | 05:01 PM
Markss's Avatar
Markss
As a fix you can cut the old terminal off and install a clamp type (clamps onto cable) terminal that can be purchased at most parts stores.
Old Feb 3, 2010 | 08:14 PM
Larry/car's Avatar
Larry/car
Some have just installed a bolt and washer.
Old Feb 3, 2010 | 08:26 PM
VET4LES's Avatar
VET4LES
The best bet is to replace the entire cable.
Old Feb 3, 2010 | 10:02 PM
Vette5.5's Avatar
Vette5.5
If it were my car, I'd replace the whole cable, as it's not that big a deal. Second would be to drill/grind out the broken bolt stud and replace it. Don't cut the clamp off and replace it with some dime store cheapo clamp on piece, as your car deserve's much better than that. Maybe try some of those red/green anti corrosion terminal felt's next time. Not sure if they help much, but only a few buck's.
Old Feb 4, 2010 | 09:17 AM
9C1's Avatar
9C1
The nut on the terminal stud is "special" in that the bottom is tapered to provide the clamping action. To the best of my knowledge the nut is not available separately from GM. As advised above, your best bet is to replace the entire cable.
Please note the torque value for the nut embossed on the bottom of the plastic terminal cover(s). I don't recall what it is without looking, but it is important to stick to it.
To battery terminate
