Side marker
Old Feb 4, 2010 | 07:46 PM
SLVR436's Avatar
SLVR436
3rd Gear
Default Side marker
Need to replace side marker lens cover how to remove thanks in advance
Old Feb 4, 2010 | 07:54 PM
ncvette_1FUNRIDE's Avatar
ncvette_1FUNRIDE
2015 C6 of the Year Finalist
Front, back, or both?
I think you can reach the rear ones by removing the rear 'outer' tail light.
I believe the front ones require you to remove the front wheel and loosen or remove the fender well liner.
Once you can reach them you twist out the light bulb assembly and you push out the side marker lenses. They are held in place by 2 plastic clips that go into square holes.
Old Feb 4, 2010 | 08:06 PM
Keith N's Avatar
Keith N
PM sent.
Old Feb 4, 2010 | 08:07 PM
SLVR436's Avatar
SLVR436
3rd Gear
Left front thanks for quick reply
Old Feb 4, 2010 | 08:11 PM
RicK T's Avatar
RicK T
Turn steering wheel to the far right. Remove push pins and small hex head screw from inner fender liner (in front of wheel) drop panel. Reach in and push out lens and holder. Start at the front of the lens and push out. There are tabs, feel them first to see which direction to push or squeeze them. There are two tabs that you can feel. Push the front most tab forward while also pushing outward. When that pops loose, then pull the rear most tab backwards while also pushing outward. They are in there pretty tight.
To Side marker
