Almost Finished Winter Service on My 05
Hi all
Been doing some winter service work on my 2005 DSO Convertible 6 Speed manual
I Know i am into OVER KILL / Over Service but it is cheep insurance
The first Cruse of the year The Greater New Orleans Corvette Club Valentine Cruse 02/28/10 is coming up quick
Thanks In advance
PS This is a you'll COME Cruse if in the area Metro New Orleans come join us
I have a couple of Questions
1. What size is the Allen plug drain for the differential ?
" The fill plug and the drain are different sizes"
The Fill is 3/8 Allen
2. Is there any thing I am missing ?
I Have completed the following
1. oil & filter 0 w 30 Amsoil
2. Coolant Change Dexcool
3. Brake Fluid Amsoil Dot .3
4. Clutch Fluid Amsoil Dot .4
5. Transmission Amsoil ATF Dextron III
6. Power Steering Amsoil Synthetic Power Steering Fluid
7. New Battery Just Happen too DIE
Still need To Do
1. Rear End Oil
2. Fuel Filter
3. Check/Change Air Filters
4. Check / Change Belts
OIL Analysis REPORT Below was on Mobil !
UNIT ID: 05 CORVETTE
EQUIP. MAKE/MODEL: GM LS-2 6.0L V-8
Gasoline Engine Oil
FUEL TYPE: Gasoline (Unleaded)
OIL USE INTERVAL:
6,257 Miles
MICHAEL: Copper was the only element out of line in this sample and
even at 195 ppm, it's not high enough to suspect a problem is
developing. GM V-8 tend to leave a lot of copper in the oil until the
get to 30,000-40,000 miles, so as long as this reads lower in future
samples, it's not a concern. All other wear looks normal. Universal
averages show typical wear levels for this type of engine after about
4700 miles on the oil. The viscosity was in the 5W/30 range and no
fuel dilution or anti-freeze was present. Try running the next oil up to
7,500 miles or 18 months.
MI/HR on Oil 6,257 MI/HR on Unit 15,464 Sample Date
12/04/09 Make Up Oil Added 0 qt s
AVERAGES
ALUMINUM 77 4 CHROMIUM 1 1 1 IRON 30 30 24 COPPER 195
195 95 LEAD 11 11 8 TIN33 1 MOLYBDENUM 85 85 82 NICKEL
11 1 MANGANESE 22 4 SILVER 00 0 TITANIUM 00 0
POTASSIUM 2 2 3 BORON 54 54 49 SILICON 18 18
15 SODIUM 99 11 CALCIUM 2421 2421 2445 MAGNESIUM 16 16
74 PHOSPHORUS 595 595 665 ZINC 724 724 837 BARIUM
0 0 0
Values Should Be*
SUS Viscosity @ 210°F 57.8 cSt Viscosity @ 100°C 9.58 Flashpoint in
°F 390 >365 Fuel % <0.5 <2.0 Antifreeze % 0.0 0.0
Water % 0.0 <0.1 Insolubles % 0.2 <0.6 TBN
416 E. PETTIT AVE.
* THIS COLUMN APPLIES ONLY TO THE CURRENT SAMPLE
FORT WAYNE, IN 46806 (260) 744-2380 www.blackstone-
labs.com
Thanks WHO DAT
Thanks In advance
Still need To Do
1. Rear End Oil
2. Fuel Filter
Gasoline Engine Oil
OIL USE INTERVAL:
6,257 Miles
AVERAGES
0 0 0
Values Should Be*
416 E. PETTIT AVE.
labs.com
Thanks WHO DAT
Fred
Premium Supporting Vendor
On my 06 CTS-V and 02 Z06 I have a 10 mm bolt...
__________________
C66 Racing #66 NASA ST2, SCCA T2
AMSOIL Dealer (Forum Vendor)
AMSOIL Ordering Information (Retail sales using reference #1206638 benefit the forum.)
AMSOIL Preferred Customer Program (Members buy at Wholesale - a savings of about 25%)
AMSOIL Catalog
AMSOIL Catalog
