whats wrong
Old Feb 14, 2010 | 12:04 PM
350z4lyfe's Avatar
350z4lyfe
Default whats wrong
I have a 05 c6...
when i use my right blinker...sometimes it works perfect....and sometimes it blinks really fast...when i get out i see...the front right blinker isn't working....so i was wondering okay the bulb is gone...but when i shut it off and turn it back on...the bulb starts working.....
kinda weird...what yall think is the problem?
thanks
Old Feb 14, 2010 | 12:16 PM
Jimini's Avatar
Jimini
sounds like a loose bulb connection.
Old Feb 14, 2010 | 12:21 PM
KenHorse's Avatar
KenHorse
From: I live my life by 2 rules. 1) Never share everything you know. 2)
St. Jude Donor '11-'12-'13, '16-'17-'18
I believe if one of the bulbs wasn't drawing the correct (i.e. enough) current, his flasher would actually slow down or stop altogether not speed up.
350z4lyfe, do you have a sequential tail lights module installed by any chance?
Old Feb 14, 2010 | 12:22 PM
SicMSP - Daniel's Avatar
0SicMSP - Daniel
Former Vendor
check the fuse too
Old Feb 14, 2010 | 02:44 PM
kellf190's Avatar
kellf190
I am going to guess you have a corroded connection between the bulb and socket. The last several bulbs I had go bad were due to this and not a burned filament. When you get the new bulb you can buy some “connection grease” to keep this from happening again.
To whats wrong
