Lowering problems! Please help..
Old Feb 18, 2010 | 01:39 PM
rcardeso's Avatar
rcardeso
2nd Gear
Default Lowering problems! Please help..
I have a 2009 C6 Z51. I cut the bushings in the rear completely off and turned the bolts all the way. Im happy with how much it lowered but the rear end now has an annoying squeeking noise when i go over bumps. Can anyone advise if they have encountered this problem when cutting the bushings? Im assuming it might be the shocks but im not sure. Please help?
Old Feb 18, 2010 | 02:17 PM
Halo 2's Avatar
Halo 2
Not surprised as you basically just made the same thing that most of the aftermarket lowering bolts consist of. My aftermarket ones did the same thing so I switched to the ones from Hardbar. If you have not done so, you may want to try putting a little grease on the lower A Arm where the pad rests.
Old Feb 18, 2010 | 02:19 PM
mcandrew67's Avatar
mcandrew67
2016 Corvette of Year
2015 C6 of Year Finalist
It is best to leave some bushing there and put grease. They sell a small piece you can insert, but the squeek is definitely from you removing the entire bushing
Old Feb 18, 2010 | 02:49 PM
Mr Guns's Avatar
Mr Guns
I haven't lowered mine yet, but from what I read...
no bushing = squeak
Old Feb 18, 2010 | 03:21 PM
designerRob's Avatar
designerRob
DUDE, WHAT MADE YOU THINK YOU COULD REMOVE THE RUBBER BUSHING COMPLETELY AND NOT HAVE NOISE! Now you have metal to metal contact between the lowering bolt and the spring! You need to buy some lowering bolts with the rubber on them and re-level your car.
Old Feb 18, 2010 | 08:55 PM
cmonkey713's Avatar
cmonkey713
Originally Posted by mcandrew67
It is best to leave some bushing there and put grease. They sell a small piece you can insert, but the squeak is definitely from you removing the entire bushing
Thats it! I always leave about an 8th of an inch on the adjusting bolt and then put some marine grease on the bottom of the remaining rubber, no squeak!
Old Feb 18, 2010 | 09:53 PM
Stickboy97's Avatar
Stickboy97
No sweat, just add some grease and the squeak will go away... enjoy the great look!
Old Feb 19, 2010 | 07:51 AM
designerRob
Once the grease wears away the squeak will return.
Old Feb 19, 2010 | 08:53 AM
rcardeso's Avatar
rcardeso
2nd Gear
Where can I buy this small piece to insert??
Old Feb 19, 2010 | 02:45 PM
brian90505's Avatar
brian90505
If you are metal-to-metal, the grease will be a very temporary fix. You can get the rubber caps from vendors like Ecklers or get some lowering bolts with the caps on them.
To Lowering problems! Please help..
