clock reset
Old Feb 18, 2010 | 06:38 PM
Larry R's Avatar
Larry R
Default clock reset
I can't believe I have to ask this, but I cannot figure out how to reset the clock in my '08 that has the Nav system. I have gone through the menus I find and looked in the owners manual but only find out how to reset the clock in the non-nav system raadio. Thanks for any and all advice.
Old Feb 18, 2010 | 06:41 PM
PJRed2008's Avatar
PJRed2008
The clock sets itself off the GPS system IIRC, you need to set whether its using DST or not. From the main screen, touch the time symbol and it will take you to a setting screen. Going from memory here as I don't have the manual with me.
Also, if you're looking in the main owners manual, you're in the wrong spot. The nav system has its own manual which includes radio functions.
VET4LES's Avatar
VET4LES
I do it twice a year and if I remember right you just push on the icon and it expands.
Old Feb 18, 2010 | 07:06 PM
Never Say Never's Avatar
Never Say Never
Good advice...
Old Feb 18, 2010 | 07:45 PM
dgrant3830's Avatar
dgrant3830
Wounded Warrior Escort '11
Yep, he's correct. Push and hold the icon for a second or so and you will find lots of fun things to play with there.
Old Feb 18, 2010 | 08:06 PM
Zymurgy's Avatar
Zymurgy
Moderator
From the Nav manual:
Setting the Time
To set the time, do the following:
1. Press the power/volume **** to turn the system on.
2. Press and hold the time display in the upper right
corner of any screen.
3. Select the 12H or 24H screen button to display the
time in standard or military time.
4. Press and hold the Hour and Min. (minute) arrow
buttons to increase or to decrease the time.
5. Select the appropriate time zone screen button.
6. Select the Daylight Saving Time screen button,
if necessary.
The radio will use the GPS satellite to set the time.
The vehicle needs to be in an open area to receive the
signal. See “Clock” under Navigation Audio System
on page 3-2 for more information.
The following time options may be adjusted from
this menu:
Hour/Min.: Touch the up or down arrows to increase or
decrease the hour or minutes. Touch and hold either
arrow to advance quickly.
12H/24H: Touch 12H to display the time in standard
time, or 24H to display the time in military time.
GPS TIME: The current GPS time will be displayed to
the right of this button. Touch GPS TIME to set the
navigation system’s time to match current GPS time.
Daylight Saving Time: Touch this screen button
to increase the time setting by one hour, then touch
GPS TIME to save the new setting. If the screen button
is light blue, the daylight savings time feature is on.
If the screen button is dark blue, the daylight savings
time feature is off.
TIME ZONE: The selected time zone will appear to
the right of this screen button. Touch TIME ZONE
to toggle through the available time zones until the
desired time zone is highlighted. The time of the
selected zone will be displayed to the right of GPS
TIME. To set the system clock to the new setting,
touch GPS TIME.
If the system is not receiving GPS information, you can
still set the time manually as described above, but
GPS time and Daylight Saving Time features will
not be available.
Touch the back screen button to go back to the
previous menu.
To clock reset
