Can anyone who installed the CCA catch can on the radiator shroud post pictures? Several have talked about mounting it there, but no one has shown pictures or talked about installation. Thanks
From: North Strand, NMB, SC; Retired x 2 (US Army: 70-90 AD) (US Army: 91-16 DAC); yea, I'm old.
I installed my CCA catch can today but chose to mount it to the block as designed because I could not find a way to mount it on the radiator shroud.
As you can see in these pics of the installed setup, I used the supplied spacer to offset the bracket and provide clearance from the block and I also turned the can so that the bottom inlet was routed under the tubing coming across the top of the engine:
