Scratch Proof Lug Nut Socket?
Old Feb 27, 2010 | 06:29 PM
Zippy's Avatar
Zippy
Cruise-In 2, 9 & 10 Veteran
St Jude donor '09
Default Scratch Proof Lug Nut Socket?
Anyone know where I can purchase a lug nut socket that won't scratch the chrome on the nut?
Old Feb 27, 2010 | 06:35 PM
arcticblast's Avatar
arcticblast
Cruise-In VI Veteran
Cruise-In VII Veteran
Try Griot's Garage. They have plastic coated sockets.
Old Feb 27, 2010 | 06:41 PM
George's_Vette's Avatar
George's_Vette
I never found a set that would protect the nuts but finally pulled the trigger on one that would protect the wheels with a plastic sleeve around the sockets exterior. I don't know that plastic on the inside of the socket (protecting the lug nuts) would stand up to the hammering an impact wrench would dish out over and over again as it's used to remove and replace the cars lug nuts.
George
Old Feb 27, 2010 | 06:59 PM
perfectlyfrank's Avatar
perfectlyfrank
St. Jude Donor '06-'07-'08-'09-'10-'11-'12
Cruise-In 8, 9 & 11 Veteran
http://www.harborfreight.com/cpi/cta...emnumber=40035
Old Feb 27, 2010 | 07:06 PM
BP09's Avatar
BP09
Cruising
Try Corvette Central part # 101910.
Old Feb 27, 2010 | 07:18 PM
MARSC6's Avatar
MARSC6
A regular 6 point socket is fine if you don't use an impact.
Old Feb 27, 2010 | 07:20 PM
SilverScorp's Avatar
SilverScorp
They have rubber-coated deep sockets in all sizes at your local Pepboys.
Old Feb 27, 2010 | 07:21 PM
mgtr's Avatar
mgtr
You may need a really long breaker bar, however. Depends on how strong you are and who tightened the wheels.
Old Feb 27, 2010 | 07:54 PM
MARSC6's Avatar
MARSC6
They should only be tightened to 100 ftlbs. I use a regular 1/2' ratchet to to loosen and a torque wrench to tighten. No marks on any of the lug nuts after having the wheels off many times.
Old Feb 27, 2010 | 08:12 PM
jackcasa's Avatar
jackcasa
I bought mine from Mid-America. . .
Old Feb 27, 2010 | 08:29 PM
Zippy's Avatar
Zippy
St Jude donor '09
Thanks guys!
Tony
Old Feb 27, 2010 | 08:57 PM
EDinPA's Avatar
EDinPA
Another option is to get a set of Gorilla twenty locks. It replaces every lug with a lock and the key engages very deep on the inside. Nothing touches the part of the nut that you see so it won't scratch.
Old Feb 27, 2010 | 09:00 PM
SilverScorp
It's not the Nuts themselves that get scratched, but the wheel opening around the nuts. Hmm, that sounded wierd .
Old Feb 27, 2010 | 09:04 PM
EDinPA's Avatar
EDinPA
so you're not worried about rusty nuts?
Old Feb 27, 2010 | 10:05 PM
rws.1's Avatar
rws.1
Mid America
Old Feb 27, 2010 | 10:26 PM
MachAll 2005's Avatar
MachAll 2005
See: http://forums.corvetteforum.com/c6-c...heel-lugs.html
at least thru post 16
To Scratch Proof Lug Nut Socket?
