Door panel rattle/buzz
Old Mar 2, 2010 | 07:31 PM
seether4113's Avatar
seether4113
Default Door panel rattle/buzz
Hey fellas, I have a rattle/buzz coming from my passenger side door panel. The noise mainly comes when there is much bass in the music, but it also sometimes shows up just driving on the highway. I attached a picture of a door panel with a red circle on it. If I apply pressure to this area, the rattle/buzz goes away. I took the door panel off and applied some sound deadener to the foam "box" on the back of the panel and while it helped some, it didn't cure the problem. Any more suggestions??
Old Mar 2, 2010 | 07:51 PM
Fonzijr1964's Avatar
Fonzijr1964
there is a bar with 3 clips that runs down the length of the door that holds on the panel. This is the most common cause of the noise u described
Old Mar 2, 2010 | 08:03 PM
seether4113
Anyone have a picture of said bar?
Old Mar 2, 2010 | 08:16 PM
Road Rage's Avatar
Road Rage
I have the same problem in my passenger door, just haven't got around to fixing it yet.
Old Mar 2, 2010 | 08:28 PM
seether4113
I had never noticed mine until I took the panel off to replace the 3.5" speakers. Ever since I put it back on, the buzz has been there.
Old Mar 2, 2010 | 09:01 PM
phileaglesfan's Avatar
phileaglesfan
Check to make sure the fasteners are secure. You can tell if they are not because the panel will pull up slightly or there is a visible gap. I removed mine to put in some insulation and a couple broke. It was the rear fastener right behind the door handle. About $6-8 for a male/female set. The part that goes in the door looks like a nut, the other is a screw with a t handle on the top to grip the panel. I put new ones on mine and the noise is gone.
Old Mar 3, 2010 | 07:31 PM
seether4113
It seems secure. There are no gaps and the panel doesn't pull away.
It sounds like something is rattling inside the "foam box" on the back of the panel underneath the armrest. I'm sure there isn't anything actually in there, but that is what it sounds like and where the sound is coming from.
Old Mar 3, 2010 | 08:19 PM
AFVETTE's Avatar
AFVETTE
My 06 and now 07 make the same noise. Dealer fixed the 06, guess I'll add this during my next visit to the dealer with my 07 Z.
Tom
Old Mar 3, 2010 | 08:40 PM
inthehunt2's Avatar
inthehunt2
Thanks for the info! Mine has the same issue on the driver's side. When I pull her out of hibernation, I'll take her to the dealer for a fix.
Old Mar 3, 2010 | 11:22 PM
phileaglesfan
I know the sound. It was the rear fastener on mine. The female part wasn't holding on to the actual door. You could always take the panel off to see if anything is loose or take it to the dealer if you didn't mess with it already.
To Door panel rattle/buzz
