Need Help
Old Mar 5, 2010 | 05:00 PM
jim k 05's Avatar
jim k 05
Cruising
Default Need Help
How do you remove the plastic retainer in the wheel well
Old Mar 5, 2010 | 05:06 PM
calemasters's Avatar
calemasters
1st pull the center pin out about 1/2" and then pull out the outer pin. You can use a flat blade or a tool such as side cutters to pull out the center pin and then the outer pin.
Old Mar 5, 2010 | 05:10 PM
jim k 05's Avatar
jim k 05
Cruising
Old Mar 5, 2010 | 05:42 PM
calemasters
Jim,
Pull out the center part of the pin first. This will allow the outer "legs" to contract, then pull out the outer body of the push retainer. I use a flat bladed screw driver to get in under the center pin and then lift the center pin up and out. Now the outer retainer component will come out since the legs are no linger expanded.
To Need Help
