NeedSolution to Sagging Floor Mats
Old Mar 5, 2010 | 07:00 PM
last901's Avatar
last901
Default NeedSolution to Sagging Floor Mats
Let me first aplogize in advance for askijng this question. I can't beleive I'm the first to do so, but I'm finding it easier to just ask the question instead of doing a long involved search.
A couple of years ago I bought a set of Lloyds' floor mats for my C6. I like them and am impressed with their quality. For some reason though the drivers' side mat (even though affixed to the anchor post on the floor) continues to "sag" or bunch-up at the point where it sits against the panel behind the pedals.
It's not interfering with pedal operation or anything, but looks pretty unsightly and is no longer proetecting the near-vertical service behind the pedals. I've taken the mats out and have hung them upside down for weeks at a time, but after a few days back in the car, they start to sag again.
This doesn't seem to be as much a problem on the passenger side as it is on the drivers' side, but I must tell you the anchor of the factory mats isn't working as well as it did for the originals.
Did I somehow forget to do something by way of the instructions provided by Lloyds?
Anyone else have this problem?
Old Mar 5, 2010 | 07:11 PM
VET4LES's Avatar
VET4LES
I don't have the problem with my Lloyd mats. How can this happen if it is anchored to the floor pin?
Old Mar 5, 2010 | 07:13 PM
AORoads's Avatar
AORoads
St. Jude Donor '15
"In honor of jpee"
I heard/read tht they are guaranteed (altho maybe not as much as the "other brand"). I'd ask your seller about a replacement for free.
Les, he's talking about the part farthest from the hook; behind the gas and brake pedals.
Old Mar 5, 2010 | 07:19 PM
VET4LES's Avatar
VET4LES
Got it. Thanks.
Old Mar 5, 2010 | 07:25 PM
last901's Avatar
last901
Well, for one thing, they don't seem to remain as anchored to the floor pin as the originals. I wonder if when I removed the originals I may have done something to not allow the Lloyds mats to adequately "anchor"? They do seem to slide back and forth on the drivers' side and that, indeed, may contribute to the sagging problem.
But the "sag" with the mats where they become relatively vertical behind the pedals, not on the floor itself. Thinnk "gravity"
Please understand I am not complaining about the design or construction. Just wondering if I'm doing something wrong.
For example, was there some velcro or double-backed tape in the package that I failed to notice?
Old Mar 5, 2010 | 07:37 PM
JERGENSEN LS3's Avatar
JERGENSEN LS3
From: New Jersey - National Corvette Museum Member '08, '09, '10, '11, '12
Pics ?
Old Mar 5, 2010 | 07:51 PM
last901's Avatar
last901
Originally Posted by JERGENSENLS3
Pics ?
Wish I could. I've never figured out how to post them - despite all the help I've been given.
Just imagine this: the floor mat on the drivers' side as you get into the car is flat - though appears to be a bit forward of where it ought to be as evidenced by the "cut-outs" for the seat rails are too far forward. That suggests to me the "anchor" for the original mats isn't working for the Lloyds (which has but a single tether) and allowing the horizontal part of the mat to move forward, yet not enough to push the part of the mat that covers the (slightly vertical) area behind the pedals to slide upwards. Therefore the horizontal part of the mats simply "bunches up" and causes this bulge at the junction of the floor and the panel that extends upward behind the pedals.
Now, remember - as I recall, that the floor mats that were supplied with the car only extended to the forward end of the floorboard and did not extend upward to the panel behind the pedals.
Geez, I hope you people aren't starting to think I'm traying to capitlize on the current Toyota issues. Be assured any acceleration in my Corvette is entirely intended and, in fact, greatly enjoyed. I just don't like the bulge in my floor mats at the base of the floorboards and the panel behind the pedals.
I can't believe I'm the only one having this problem - unless I've done something wrong in installing the Lloyds mats.
Old Mar 5, 2010 | 09:13 PM
AORoads's Avatar
AORoads
St. Jude Donor '15
"In honor of jpee"
after years of use, doing something wrong? I doubt it. call lloyeds.
Old Mar 5, 2010 | 09:20 PM
bob guzzy's Avatar
bob guzzy
I would think the mats are just old and tired and lost the stiffness that held them in place, there is heat from the exhaust and engine that migrates thru the floor, along with from the heater ducts and I'm sure the material isn't want it used to be a few years ago.
Old Mar 5, 2010 | 10:10 PM
calemasters's Avatar
calemasters
It sounds like the mat has lost its rigidity. You may want to call Lloyd Mats to see what they will do. Phone (818) 768-6001.
I have the "post" retainers and the mats snap on over the post very tightly. Too tight in my opinion. My wifes 2010 Malibu has the "hook" system and the mat stays in place OK. As mentioned in other post, you may have the wrong mats for the retention system on your car, which changed mid 2007 for the Corvette. I think the mid year production change caught LLoyd Mats by surprise. If you have the hooks and your mats are designed for the post retention system, the mat will not stay in position.
Mine are 5 years old (as of today) and still like new.
Old Mar 5, 2010 | 10:11 PM
CO Lightfoot's Avatar
CO Lightfoot
Originally Posted by last901
Well, for one thing, they don't seem to remain as anchored to the floor pin as the originals...
Maybe you've got the wrong mats for your fastening system.
I assume your 07 C6 has the "post" system. So maybe you received "hook-system" mats?
Post system (May 2007 and earlier)
Hook system (May 2007 and later)
As of May 2007 GM changed their fastening system for Corvette C6's to a dual hook system (on the driver's side and single hook on the passenger side) from a post system that was used previously. To ensure your mats fasten in place correctly, please check your fastening system and choose the correct option before ordering...
http://www.southerncarparts.com/corv...mats-p-97.html
Old Jun 10, 2010 | 01:25 AM
brucemc's Avatar
brucemc
I have the same exact problem. My mats are 5 months old and the post correctly matches up to my post in the car. I thought about using velcro but I'm not sure that the tape will stay attached to the carpet or matt. It's frustrating but managable. I feel your pain.
Old Jun 10, 2010 | 01:44 AM
WMark's Avatar
WMark
St. Jude Donor '11
You know what, I've got to on this one. Not knocking the vendor, or Lloyd (well, maybe I am...) but I bought mats for my 2006, and I constantly had to pull the suckers away from the go pedal, brake and clutch.
YES, I had the right floor mount, but it wouldn't hold. It took several months for me to realize it wasn't me. Yeah, I should have complained earlier, but my '06 wasn't a DD, so only realized the problem every few months. Out of sight, out of mind.
Traded the '06 off. New owners have the good looking mats. After my 2006 experience, I'm sticking to the stock stuff. Don't show the car, and only my boot heels know the difference... And they don't care.
Thanks for sharing your experience. I thought it was just me!
Old Jun 10, 2010 | 02:31 AM
AtHomeSoda's Avatar
AtHomeSoda
Default well..
2006 here.. 26,000+ miles... no sag with the lloyds.. not sure what the problem is with yours...fyi
Old Jun 10, 2010 | 02:26 PM
Gearhead Jim's Avatar
Gearhead Jim
St. Jude Donor '13
Old Jun 10, 2010 | 03:26 PM
NYC6's Avatar
NYC6
Had the same issue with my Lloyds after 2 years. Wouldnt lay flat and bunched up, looked terrible and my car is a fair weather vehicle only. The only time it really gets wet is when I wash it. I chucked them in the garbage and went back to OEM mats.
Old Jun 23, 2010 | 01:37 AM
brucemc's Avatar
brucemc
Update - The two sided velcro tape has worked like a champ.
To NeedSolution to Sagging Floor Mats
Old Jun 23, 2010 | 01:46 AM
rockdude's Avatar
rockdude
Great to hear that, I was going to suggest a hammer and nails though.
Old Jun 23, 2010 | 06:16 AM
theofel's Avatar
theofel
St. Jude Donor '10-'13
My Lloyd mats do the same thing. Not only do they sag but they turned color after one year...from a dark grey to a green grey. Discussed with vender and was told he has heard this before and the color change is because of the Florida sun. Sounded feasable..but...Why did the rear cargo mat by Lloyds stand up well and still looks new. Maybe the Lloyd mats are prone to the heat of the floor in the Vette. Make a long story short ...the vender did Squat for me. Unfortunetly the Lloyd mats are really the only game in town. Maybe they only have a one or two year life in a VETTE. Probably going to order another set and see what happens.
Old Jun 23, 2010 | 08:07 AM
SRQStingray's Avatar
SRQStingray
My Lloyd's mats are less than 8 months old and the carpet is fraying where the edging is attached. As for Florida sun, why would they fade when no other floor mats that I have had in Florida have faded?
